Adrian wrote:If you flipped the board when gluing up so that any angle on the edges cancelled out it would probably work but an edge jointer or just a long hand plane would probably be just as quick. You've got bit deflection, material lining up, gantry plumb etc etc to worry about on the CNC.
Hi Adrian,
Thanks for the reply.
My problem is the wood can be too heavy to run through the jointer, plus I don't have a jointer hand plane.
What if instead of trying to edge the board we plunge down about 1/8" per pass,
and take 1/4" or so off the edge of the board.
as far as making sure the board is at 90 degrees of the gantry..
jog the gantry from one end to the other to check
Just a thought...
