I've starting a project to machine 3d parts.
I have cad software so, i can modify the part if needed.
I have found some .dxf pieces. The problem is when i import into vcarve pro.
I've created the project.
go to modeling, open the "folder" find the file and import into vcarve pro.
at this point I get the error "failed to load component data from file . file name . check file contains model.
the dxf is editable in the cad software. So, how is a model added to the file.
Cad software is "TurboCad Deluxe"
Error importing 3d models -- import does not contain model
Re: Error importing 3d models -- import does not contain mo
For DXF 3D files the data must consist of meshes or triangles. Can you upload an example DXF file you are using?
is it definitely a 3D DXF file & not a 2D DXF file ? Have you tried importing it as vectors ?
Have you tried exporting in from you cad program as a different file type such as STL or OJB
3D .dxf files can contain many different types of entities, and Vectric only imports a small portion. You really need to know what you're doing when working with 3D .dxf' files.Rcnewcomb wrote:For DXF 3D files the data must consist of meshes or triangles. Can you upload an example DXF file you are using?
- adze_cnc
TurboCAD still exists? Who knew?
It appears that some of the more recent versions of TCD export .STL files for 3D printing. How about using .STL instead of .DXF?
