Ramping into a pocket
Postby Wdp67 » Tue Dec 22, 2015 12:11 am
Hey all!! Thanks for helping me on my earlier post about Mach3. Finally making some real parts, and trying to use the ramping feature in a pocket. I can't seem to get it to work, can someone walk me thru it? Basically what I am trying to do is face of my workpiece, but I need the tool to not plunge straight down into my material. I got it to work once by accident, but can't for the life of me remember how I did it.
Thanks!!
Walt
Wdp67
Model of CNC Machine: 6040Z-DQ
Re: Ramping into a pocket
Postby Bob CVA » Tue Dec 22, 2015 1:22 am
After selecting Pocket tool path, check the box that says you would like to consider advanced options. I believe it is in the upper most box.
About two thirds of the way down the menu there should be a box that allows you to ramp plunge moves. It can be selected, and will ask you the distance over which you would like to plunge.
I think that is what you are looking for.
Bob CVA
Model of CNC Machine: Shopbot PRS 48x96
Postby Wdp67 » Tue Dec 22, 2015 2:26 am
Yes that's it but when I do it, it doesn't ramp, it still just plunges strait down into the material.
Wdp67
Postby FixitMike » Tue Dec 22, 2015 3:44 am
Did you Recalculate Toolpaths and then save the new toolpath?
FixitMike
Postby Wdp67 » Tue Dec 22, 2015 2:15 pm
Yes sir, I tried it several times, looked at the code and there was no ramping. Late last night I shut my computer down and restarted. When I tried it again it worked. I'm not sure what was going on, but I did get it to work.
Thanks for your help!
Wdp67
Postby Travishuffman » Fri Nov 03, 2017 3:56 pm
I have done all that was mentioned in this post and I'm still getting no ramping in a pocket tool path. cutting a 3/4" pocket with a 1/4"bit 1/4" deep. set rampimg to 4" distance when i check the toolpath in 3d view no ramp. Please help.
Travishuffman
Model of CNC Machine: Shop Sabre 4814
Postby martin54 » Fri Nov 03, 2017 4:16 pm
Can you post a couple of screenshots of how you have it set up as that will help the board experts doesn the wireframe toolpath view not show the ramp ??
Postby Travishuffman » Fri Nov 03, 2017 4:26 pm
It was working yesterday just fine and I changed my material size from 4x8 to 5x5 once I recalculated and saved the toolpath and ran the part, no ramp.
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 4:34 pm
hopefully that is what your looking for. Thank you so much for the help.
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 4:52 pm
I tried copying the vectors to a new file and starting the toolpath process from scratch and stillno ramp. then i just drew a rectangle and toolpathed that as a pocket and the ramp shows up
there so that tells me its something to do with my file
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 5:02 pm
now I've tried removing the fillets no luck. then I tried to offset the whole thing outward 1" and still no ramp. weird!
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 5:06 pm
here is the file
THOMAS-BOX1-2-5X5-SHT-1.crv3d
(132.5 KiB) Downloaded 23 times
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 5:09 pm
sorry not the same one i was sending shots of but this one is doing the same thing
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 5:31 pm
Now I changed the bit to a 1/2" and the ramp shows up which is really the bit I should be using I know but anyway I changed back to the 1/4" bit and changed the step-over to 80% and that did it! Hopefully all this is helpful to someone down the line.
Travishuffman
Postby Travishuffman » Fri Nov 03, 2017 6:12 pm
Has anyone looked at this file and saw the same problem I did? Just curious.
Travishuffman
Next
Return to VCarve - General
Users browsing this forum: bobrickard and 24 guests
