Create two part mould for spheres
Re: Create two part mould for spheres
Postby highpockets » Mon Oct 30, 2017 4:21 am
I put boundary vectors around the components and used Select Vectors under Machining Limit Boundary.
Postby jbbjshlws » Mon Oct 30, 2017 8:43 am
highpockets wrote:I put boundary vectors around the components and used Select Vectors under Machining Limit Boundary.
That has worked a charm, I dont quite understand why we needed to zero it first to get clean edges but it is working so awesome :-)
jbbjshlws
Model of CNC Machine: x61500gt
Postby Adrian » Mon Oct 30, 2017 9:21 am
jbbjshlws wrote:That has worked a charm, I dont quite understand why we needed to zero it first to get clean edges but it is working so awesome :-)
It's to give the software a surface to blend into. Otherwise the edges of the spheres are just going off into what the software sees as empty space.
Previous
Return to Aspire - General
Users browsing this forum: No registered users and 18 guests
