tappering the curved wall of a bowl on the z axis
anyducks
Model of CNC Machine: 1 Shark HD
Post by anyducks »
Been away for a while. I have been trying to cut a bowl with curved sides on the z axis.
Can I do this with the pocket to curve the sides on the z axis?
Do I need to use the tapper ?
Re: tappering the curved wall of a bowl on the z axis
Post by mtylerfl »
Have you kept current with the most recent versions of the software? (What version are you using?)
Answers can vary depending what version of VCarve you are using.
anyducks
Post by anyducks »
vcarve pro 9.009
Post by mtylerfl »
Would using any of the 3D dome shapes included in your VCarve Pro 9 software clip art do what you want? You can distort/resize as you wish.
Or maybe you can use the Molding Toolpath feature or the Fluting gadget to achieve your tapered sides shape.
anyducks
Post by anyducks »
Tapering will work. It takes a lot lines.
PaulRowntree
Post by PaulRowntree »
Can you post a sketch of the shape you are after? The approach to take might depend on the complexity.
Paul Rowntree
anyducks
Post by anyducks »
attached is a photo of the bowl. I want to make it a two sided job .
Post by mtylerfl »
I would try the Moulding Toolpath for that. One for each side.
anyducks
Post by anyducks »
I have not tried the molding process. Thanks for the suggestion
Daner
Model of CNC Machine: Industrial 8x4
Post by Daner »
Im very impressed that that bowl can be made with Vcarve pro.
I may try a one side tool path to make a Nut dish.
Very slick.
Post by mtylerfl »
Vectric Guru, Michael Mezalick showed an example (quite awhile ago) of making a bowl/dish using the Molding Toolpath feature. Here is the link...
http://forum.vectric.com/viewtopic.php? ... ng#p188945
