made a cupboard door for a guy at work, with a large pocket and raised letters. large area clearance with a .5 inch end mill then finish pass with .125 inch. the toolpath preview looks fine but in the letter 'a' and 's' a bit was left behind?
Also the toolpaths generated had some really wasteful moves where it was carrying out a ridiculous amount of small plunges to nibble a bit then move. i think the time could have been halved without these small plunges.
Any thoughts
pocket missed a bit
- Model of CNC Machine: X-Carve
pocket missed a bit
- bobs door part 1.crv
- (1.96 MiB) Downloaded 94 times
Re: pocket missed a bit
Those parts coincide with the two different toolpaths for the pocket so it looks like two different types of bit were used (downcut, upcut) and/or the z-zero wasn't set accurately between tool changes.
There is often a slight difference where the clearing and main toolpaths meet but this is far more pronounced than that.
That is sometimes a sign that the area you are trying to machine is the sames size/too small for the specified end mill.Also the toolpaths generated had some really wasteful moves where it was carrying out a ridiculous amount of small plunges to nibble a bit then move. i think the time could have been halved without these small plunges.
An alternate way to approach this design is to use a VCarve strategy with a flat depth using the V bit and the 1/2" end mill.
See the attached file for an example.
- bobs door part 1Alternate.zip
- (621.06 KiB) Downloaded 93 times
