Is there a way to create a texture using the "texturing toolpath" tool but then save what would be the result as an .stl file (or even a depth map)?
To put it another way, if you render the toolpath, I'd like to save what the preview looks like as an stl file. This would allow me to generate textures using the tool based on tools that I do not have but then I could go back and machine surface created using a router bit that is common. For example, it might be useful to generate the texture assuming I had a 4" ball mill. But because it would be hard or impossible to actually find and/or run a 4" ball mill I could then take the surface created and carve it using a 1" ball mill.
Thanks in advance!
Jeanyes
Any way to save "texturing toolpath" as .stl file?
- mtylerfl
Re: Any way to save "texturing toolpath" as .stl file?
Run your toolpath preview, then save the preview as a component via the Model Menu/Create Component from Toolpath Preview. Then, you can export the component as STL if you wish.
- Model of CNC Machine: Thermwood CS-45 5 x 10
Will that work with molding tool path as well ?
Will Williamson willmade.com
Capac, Michigan
Capac, Michigan
- mtylerfl
Do you own Aspire? If so, then yup! Try it yourself when you have a chance.Will Williamson wrote:Will that work with molding tool path as well ?
- TReischl
That is pretty neat Michael! For some reason (probably slightly damaged brain cells) I never noticed that could be done before.
Thanks!
And here I am, a Vectric Wizard. . .some "wizard", more like "sorcerer's apprentice" at times.
Thanks!
Thank you very much! Somehow I totally missed the option to create component from preview option. Sweet!!
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
- mtylerfl
jeanyes wrote:Is there a way to create a texture using the "texturing toolpath" tool but then save what would be the result as an .stl file (or even a depth map)?
I forgot to answer the depth map portion of your question. Again, the answer is yes - you can export a model/component as a grayscale graphic (depth map) via Model Menu/Export as GrayScale Bitmap
I have fond memories of this feature addition! Many years ago, Tony McKenzie (one of the Vectric Founders) asked me how Aspire could be utilized for CarveWright CNC software users. At that time, the CarveWright software did not have a way to import STL models (it can now), but COULD import grayscale bitmaps (depth/height maps). So, I told Tony that's how Aspire could be useful for CarveWright users. Next thing you know, the Export as GrayScale Bitmap feature was added to Aspire!
How long has this feature been available? Save preview as component.
Capac, Michigan
Capac, Michigan
- mtylerfl
I don't recall exactly, but it has been many years.Will Williamson wrote:How long has this feature been available? Save preview as component.
