Tombstones - Eps foam
- customquint
- Model of CNC Machine: AXYZ
Doing some experiments with Eps foam for an upcoming project . Made these with the Halloween season coming.
Hard coated with Stryroplast.
Painted the in shops creepy basement.
- customquint
Re: Tombstones - Eps foam
customquint wrote:Doing some experiments with Eps foam for an upcoming project . Made these with the Halloween season coming.
Painting in the shops creepy basement.
- dwilli9013
Nice I still have yet to try the foam. Like the finish on those. Thanks for sharing.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- kp91
- Model of CNC Machine: Digital Wood Carver
Where do you get the foam from? There are a few rigid insulation foam boards available through my Hardware store, about $10 for a 2' x 4' x 2" sheet of AMVIC foam. I don't know if it would work or not.
1 John 1:9
Fredericksburg, VA
1 John 1:9
Fredericksburg, VA
- customquint
These where made with hardware store eps foam rigid insulation, bewteen 10 and 20 a sheet depending on the store.kp91 wrote:Where do you get the foam from? There are a few rigid insulation foam boards available through my Hardware store, about $10 for a 2' x 4' x 2" sheet of AMVIC foam. I don't know if it would work or not.
- kp91
I might just have to go and give it a go!
thanks
thanks
1 John 1:9
Fredericksburg, VA
1 John 1:9
Fredericksburg, VA
- krugshouse
- Model of CNC Machine: Blackfoot v4.2, VCP 8, Mach 3
- dwilli9013
Nice that's a game changer for home built Halloween displays. Thanks for sharing.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- customquint
nice, do you have those hard coated?krugshouse wrote:I love working with foam, never break bits.
- krugshouse
I cut them just they way they come from Lowes. I either paint them with UGL dry lok to give it a cement look. Or I paint them with ext. paint. all sides and edges. Since they are for Halloween and are only out a couple of days they seem to be holding up OK.
Have a safe machining day
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
- Model of CNC Machine: Pro Carv
As a memorial mason I have had some funny inscriptions to carve.
Rev. John Thomas, and a Robert Early Cummings are two that come to mind.
R
R
Hello,
I saw this Halloween foam Tombstones and love the idea of making them out of foam.
My only question is how are they anchored to the ground? Even though they have a wide base, a light breeze would knock them over.
Mike
Mike
A while back I did some very large models from foam that I hand plastered with a cement mortar that turned out okay but wasn't as rigid as the Stryroplast. I'll give it a try on the next foam project. Thanks for the information. By the way, great job on the tombstones.
Gary
Gary
