box making gadget
Re: box making gadget
Postby Adrian » Mon Sep 11, 2017 6:53 pm
If you use the normal dovetail gadget you can make the sides without dovetails on the bottom. Little bit more work though.
Postby lawrence » Tue Oct 17, 2017 3:55 am
dah79 wrote:Using the box gadget, is there a way to not have the dovetails made on the bottom edge of all the parts? I do not have selected to make a top or bottom. I would like to just have a straight bottom as I will put a dado in all the sides for the bottom.
This looks like a pretty cool gadget. Maybe I am asking too much... Thanks
I tested using the node edit mode to delete the dovetails on the bottom- when I recalculated, the imported pin carvings created an error, but that didn't seem to have an effect on the rest of the recalculation and it (appears) to have worked!
not a perfect workaround, but it seems to be a workaround for this very cool gadget. I'm quite excited to give it an actual try on my machine :)
Hope this helps-
Lawrence
lawrence
Model of CNC Machine: CNC Shark HD
Postby sharkcutup » Tue Nov 14, 2017 1:51 pm
its there now, just downloaded it
http://gadgets.vectric.com/V9/box_creator.html
I have downloaded that particular file and it does not install. Noted that the file extension is .vgadget and not .exe so this is probably why it would not install.
Sharkcutup
Facebook: Hogan's CNC Crafts
V-Carve Pro 9.518
sharkcutup
Postby Adrian » Tue Nov 14, 2017 1:54 pm
Vgadget is the correct extension for V9 products that support gadgets. They can be installed by double clicking the file or by using the Install option on the gadgets menu.
Postby spottsd » Mon Nov 20, 2017 10:02 pm
I am having trouble trying to install the boxmaker gadget
Does it work with Aspire 8.5?
How do I get it installed?
Cheers
Dave
spottsd
Model of CNC Machine: Legacy Arty
Postby Adrian » Mon Nov 20, 2017 10:36 pm
It's not available on the pre-version 9 gadget site and the v9 format gadgets won't install in earlier versions.
The dovetail gadget is available though and you can make boxes with that - http://gadgets.vectric.com/V8/dovetail.html
Previous
Return to Gadgets - Releases
Users browsing this forum: No registered users and 0 guests
