Spiral Square with an arc
- Martin Reid
Re: Spiral Square with an arc
Dear Jay
You can model your twist in SketchUp - Then use Export to DXF or STL (Plugin from https://www.guitar-list.com/download-so ... dxf-or-stl) then drop the 3D DXF into Aspire (or Partworks 3D)
The one I've demonstrated has quite big segments you will be able to make them smaller and give you a better resolution.
Sincerely
Martin Reid
Sincerely
Martin Reid
- mezalick
Martin,
It's all well and good but your's doesn't have the arc......
I don't know Sketchup so I'm interested to know if you can add the bend to the twist .
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Martin Reid
Michael
Michael Mezalick has it if you have version 9
SketchUp.. Yes you would be able to 'twist' then bend the 'arc'. The problem is of course having to learn another piece of software. If it was me and I had Version 9, then I would look at Micheal's 'Done with V9 and the wrapped Job Gadget'
Sincerely
Martin
Sincerely
Martin
- mezalick
Interesting,
Thanks Martin.
As I said I don't know much about Sketchup ,,, my bent spiral can be done in any version of Aspire that has the wrapped gadget..
Michael
Thanks Martin.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
I guess if I played with it with a two rail sweep, I could do it in Aspire, but sometimes an outside cad software is faster. 30-seconds with Rhino I came up with this. I couldn't post it as a stl or rhino file, so I attached it as a dxf. See if that works. Gary
- twisted post.dxf
- (187.57 KiB) Downloaded 161 times
Needs to have an arc in it though. That's the issue, it's not a straight post with a 1/4 turn.
Just another few seconds in Rhino. However, just guessing on the degree of arc.
- Twisted with arc.dxf
- (118.44 KiB) Downloaded 161 times
- mezalick
Of course there are several other programs that can do this, I would have used MODO, but for me the challenge was to only use Aspire..
Certainly I'm not the only one that can do that....am I ????
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- dealguy11
I have made things quite similar to the stair spindle shown earlier. Here is a picture. I'll have to pull up the old file - I ended up using a Multiply sweep to get it to come out right.
- mezalick
Steve,
Correct me if I'm wrong but your designs don't seem to have a bend to them...??
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- dealguy11
Sorry, missed that.
It should be possible to add a bend by adding a carefully constructed 2-rail sweep that pulls the design down in the middle, but there is a limit to how much of a bend you can do in Aspire. As always, the closer the surface of the part is to the center line, the more distortion you'll get, and if the center line is exposed, Aspire can't handle it.
