First time trying to use the dovetail gadget so my issue could be user related.
When trying to create a dovetail, based on the tutorial I watched, I get a different end result. My dovetails on one end are being created outside the initial shape. I see that if I change the start point, so that it is different on each end, then it works correctly. Is this a required step, as I didn't see that in the tutorial?
I have downloaded the V9 compatible version...
First time dovetails
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
Dave
Re: First time dovetails
Does nobody use this gadget? More curious if this was an issue with the 8.5 version.
Dave
Never had an issue with it like that but I always cut the vectors in the same order so I wouldn't have come across it. It works the same way as 8.5
- Model of CNC Machine: Fine Line Automation
I just tried to use it in ver. 9 I'm having the same unsuccessful results as you. The pins are also forming outside the original shape. Fortunately I did not uninstall 8.5. It works fine in 8.5. Looks like it needs some work for ver. 9. Glad I read your post or I'd still be messing with it.
Thanks for letting me know. I hadn't tried it before V9.
Dave
It works in exactly the same way as 8.5 for me. You need to have the start point in the correct place in either version.
Looks like I was lucky when I tried it in 8.5. I tried it again in 9 making sure none of the lines shared a start point location and it works as expected. I stand corrected. It works fine. I've been waiting for this day for a long time. 70 years old and I finally made a mistake.
