Just purchased aspire 9.* and I am quite happy with the changes
Its good to see a bunch of video tutorials and worth going through them
I highly recommend Vectric aspire to the people I work with on the net, I will be using aspire 9.*
on my drawing demos
Do the original 8.5 fonts get carried to aspire 9. ?
aspire 9.009
- mtylerfl
Re: aspire 9.009
Hi Stan
As far as I can tell, all the Vectric single-line fonts are the same.
All other available fonts are whatever resides on the particular computer system you are using (nothing to do with any Vectric software of course).
Re: aspire 9.009
thanks, I seem to get into special fonts so I guess I will have to manually load them again
not a big deal.
Like your projects, should do one soon again
The last cheese board looked good
stan
not a big deal.
stan
- mtylerfl
Re: aspire 9.009
Thank you, Stan!
Quick question...are you installing the new software on the same computer you're using the previous version? I ask because if you are, then you won't need to re-install any of your fonts.
Re: aspire 9.009
Software uses the fonts installed in the windows font folder Unfortunately there is no option to use any other fonts. Apart from the single line fonts obviously which can't be added to.
So if you are using the same computer you ran 8.5 on then as Michael says you won't have any fonts to re install
Re: aspire 9.009
ok thanks, it has all worked out.....
- mtylerfl
Re: aspire 9.009
Good job, Stan! Now you can have some fun!stankern wrote:ok thanks, it has all worked out.....
