Adding to previous model?
Re: Adding to previous model?
Post by highpockets »
Kathy,
What do you want to do with the text? Vcarve it into the bar or have it stand proud?
I'd move the bar down just a bit.
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Post by oldlogtrucker »
The more I think on it stand proud would be nicer. I am putting a Roland Vinyl in the for the center text.
That was a good thought. Thank You.
Have you ever been to the omak Stampede and Suicide race? Not sure where you are. The world gets so small with internet.
Thanks again Kathy
Embroidery - WingsXP
Just googled Omak Stampede. Oh hell no!!! Might watch, but I prefer a trail ride pace :D :D :D
OK going with the raised text.
I'd still move the bar down a bit.
Kern the text using the "Edit Text Spacing and Curve" to move the letters apart a bit more, so a 1/16" bit can fit between the letters.
Highlight the text then click the "Model" tab. Click the "Create Shape from Vectors" under "Modeling tools".
These are the setting I used on your project.
Image 010.png (9.84 KiB) Viewed 3051 times
oldlogtrucker
Is there a way to set the kerning in the beginning or do you just have to do each letter individulally?
And where do you reside., just out of curiousity
Thanks Kathy
oldlogtrucker
Thanks Kathy
oldlogtrucker wrote:Is there a way to set the kerning in the beginning or do you just have to do each letter individulally?
Sorry, you have to kern each letter.
Just a note: If you curve text then change the text you have to start over with kerning.
oldlogtrucker wrote: And where do you reside., just out of curiousity
Thanks Kathy
Not sure what you're asking.
oldlogtrucker
To move the letters a bit apart do you have to click on each letter individually or is there a set up that you can create the letters spaced as you want?
Hope this makes more sense?/
Kathy
oldlogtrucker wrote:To move the letters a bit apart do you have to click on each letter individually or is there a set up that you can create the letters spaced as you want?
Kathy
You have to kern each letter individually.
Kathy, you made me think about this just a little bit. Thanks for making me think.... :D
Yes there is a way to automatically "space" (not kerning per say) a line of text.
Create the line of text as usual.
Next draw a horizontal line the length you want your text to span.
Select both the text and line.
Using the "Text on a Curve" option, now you have control over the spacing.
oldlogtrucker wrote:And where do you reside., just out of curiousity
Just outside Houston, Texas
oldlogtrucker
Re: Adding to previous model? finally done.
Well, except for the hangers I am done.
Turned out really good!!
Thanks for letting us see the final results.
Hard to tell from the picture, did you do raised letters?
rsetina
Model of CNC Machine: Shark HD 2.0
Post by rsetina »
That was a fun read. You did a very nice job on the horseshoe Kathy.
Rick
Shark HD 2.0
oldlogtrucker
No raised lettering. It failed so I covered it. For me every project has fixes.
Thanks again to everyone for all the suggestions and help.
Kathy
oldlogtrucker wrote:No raised lettering. It failed so I covered it. For me every project has fixes.
Kathy
What do you mean when you say it failed ? Great when you have work rounds or can make alterations to a project rather than start again but what about your next project ? If you know why it failed then you won't do the same thing again :lol: :lol: :lol:
