Re: Re: Version 9.0 is here. Upgrade Now!
I've just tried every 3DS file I could find on my PC and they all generate the same error when trying to import them. STL versions all work.
- highpockets
Same problem.... Can't import 3ds files.
Imports just fine in v8John
- Vectric Staff
- Model of CNC Machine: Craft CNC DS1
Exporting the top and bottom models as a single STL model will follow in the near future.GeneMpls wrote:Adrian- I am hoping you can answer a V9 question for me. I am battling with other software and I am wondering if I can design in Aspire and export STLs for 3d printing- I know I can do it for one-sided models. I have a lot of experience with Aspire V8 and will upgrade to V9 if it will do what I desire. I want to do what is considered an undercut in V8 and produce a STL from it? This is a sample I have printed- I would like to add a feature to the bottom side and then export. Thanks Gene
Mohamed
Mohamed
Mohamed
- Vectric Staff
This will come back in the next update. Follow the release notes on how to get access to it.KennesawGA wrote:I just upgraded from Vcarve Desktop v8.5 to Desktop 9 and I am very happy with all the improvements. But I do not understand why the ability to pull the list of Toolpaths out as a floating window was removed in V9.
In version 8 and 8.5 there was a small button on the bottom right of the screen (to the right of the "Show 2D Previews" and "Solid" check boxes. When that little button was clicked the "Toolpath Control" panel would open and it could be dragged around the screen.
This was very useful when a project had lots of toolpaths and you were trying to group toolpaths with the same tool together for saving.
Is there another way to do this now, or did we loose that little bit of functionality in V9?
Picture of what I am talking about is attached.
Mohamed
Mohamed
Mohamed
- Vectric Staff
The issue importing 3DS and OBJ files has been fixed for 9.009. Sorry about the inconvenience caused!
One tip for the future, if I may: It's quicker for us to spot issues / concerns / complaints if they are reported in their dedicated topics. It's easier for everyone to follow what's going on then, and respond to them. That will help us help you better and would be greatly appreciated
Thank you
Mohamed
Thank you
Mohamed
Mohamed
Mohamed
- Model of CNC Machine: Shark HD4
I still can't import 3ds files in V9. Tried upgrading but it tells me I have the latest version. Maybe I'm doing something wrong. Has anyone gotten it to work with windows 10.mohamed wrote:The issue importing 3DS and OBJ files has been fixed for 9.009. Sorry about the inconvenience caused!
Thank you
Mohamed
- mezalick
It appears that 9.009 is not out yet....
Hang in there,,,any day now.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: EZ-Router
I am a little confused.
I downloaded the Trail Version and it opens .3DS files just fine.
See attached picture.
Aspire Trail Edition 9.007
I am running Windows 7 Professional 64 bit.
Joz
Joz
Because the issue is with Windows 10
Thank you, Garryger21 wrote:Because the issue is with Windows 10
So; the “newest and latest technology” is not always the best ………
Joz
9.009 is out now and importing 3DS files under Windows 10.
Confirmed fixed on my system.9.009 is out now and importing 3DS files under Windows 10.
Hi,
I know that Aspire is made primary for CNC machining but as version 9 has lot of spining, turning two sided tools...
Can person create a 3d model to be exported so it will be printed on 3d printer?
I found out some parts are more economic to print than to mill (like "duh"...)
Upgrade for 400 is quite much especially if I don't particularly use new features.
But I like working with aspire and such side possibility would be very useful for people like me.
Thanks for answer.
Yuri
Thanks for answer.
Yuri
- mezalick
MrYuri wrote:Hi,
Thanks for answer.
Yuri
This may be a clue,
http://forum.vectric.com/viewtopic.php? ... 57#p200957
" Exporting the top and bottom models as a single STL model will follow in the near future.
Mohamed"
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Thanks Michael.
This may be a clue,
Mohamed"
Michael
Hope they don't mean near future version 10 for another 400$
Will wait untill feature is added and then upgrade. Or at least when I'll need added features in Aspire9.
