pandrade82@gmail.com
Post by pandrade82@gmail.com »
I'm a new Vectric user so forgive me if I'm not posting my question in the appropriate forum. I'm using VCarve Desktop Ver. 9.008 and have a basic question. I'm trying to resize a circle and can't seem to do this. Seems like it should be a very simple thing to do but checking withing the software and searching on the forums I can't seem to find the answer.
Kind regards,
Peter
There are three main ways of resizing a circle. First (which works with any shape) is to use the size tool; second icon under transform objects or press the T key.
If it's a circle created in VCarve you can use the Circle tool (first icon under Create Vectors) to resize.
Lastly you can go into transform mode (double click) on the circle) and then use the mouse to drag one of the corner squares.
If you haven't been though them yet it's a good idea to work your way though the tutorials in the Video Tutorial Browser it will help with the learning curve.
Thank you Adrian for your help. Is there a way to re-size with an exact size? For instance if I have a circle that is .250 in diameter and I want to resize to .500 can this be done?
Again thank you for your help!
Peter
Yes either of the first two option let you type in an exact dimension.
There is also a gadget - http://gadgets.vectric.com/V9/circle_resize.html - that will resize many circles all in one go.
Thank you Adrian, much appreciated.
Peter
Adrian wrote:Yes either of the first two option let you type in an exact dimension.
The OP is using Vcarve Desktop Adrian so using the gadget isn't going to be an option :lol: :lol:
seanm
Post by seanm »
Hi Peter,
As Adrian mentioned, looking through the Video Tutorials will help a great deal, you'll find the Tutorial Browser at the link below,
http://support.vectric.com/tutorials/V9 ... =2&order=1
This will take you straight to the Getting Started Videos, I think once you feel comfortable with those, you could look at the Introduction to Drawing Vectors
http://support.vectric.com/tutorials/V9 ... ideo_id=99
& The Vectric Widget video
http://support.vectric.com/tutorials/V9 ... ideo_id=16,
which goes into a lot of detailed information about all the different ways you can draw and resize vectors along with utilizing keyboard shortcuts to make the process even more efficient.
Sean
weasel2003
Model of CNC Machine: shark plus pro
Post by weasel2003 »
I purchased photocarve years ago and still have the order number and registration number. when I upgraded my computer I had no disk for photocarve so I downloaded the trial version and it wont let me enter the registration number. help please with this issue.
FixitMike
Post by FixitMike »
weasel2003 wrote:I purchased photocarve years ago and still have the order number and registration number. when I upgraded my computer I had no disk for photocarve so I downloaded the trial version and it wont let me enter the registration number. help please with this issue.
E-Mail Support@Vectric.com for help with the license.
The trial version can't be used as you have discovered, when this happened to me I contacted Vectric Support who sent me a new download link, I then saved a copy of the download & put it away safely for a rainy day. :lol: :lol:
Probably won't ever need it now though because my customer portal now contains a download link & registration details for photvcarve as well as Aspire & varve pro. If you have a customer portal check in there for it if not conact Vectric Support as Mike has suggested :lol: :lol:
subtleaccents
Model of CNC Machine: Techno LC 4896
Post by subtleaccents »
I have a request the I hope can be easily satisfied!
I have downloaded the V Carve Pro tutorial and it is a bit troublesome for me to understand the operation of this software. I'm a slow learner so it would be beneficial if I could find classes that I can attend to understand the use. Is this a request that has a resolution?
I'm located in Cape May County New Jersey.
Thanks in advance for any help this forum can provide.
JT
Post by highpockets »
subtleaccents wrote:I have a request the I hope can be easily satisfied!
JT
Vectric has some of the most comprehensive set of tutorial videos http://support.vectric.com/tutorials/V9 ... =1&order=1
I recommend watching each video, on most if not all they have downloadable material so you can follow along.
LittleGreyMan
Post by LittleGreyMan »
highpockets wrote:Vectric has some of the most comprehensive set of tutorial videos http://support.vectric.com/tutorials/V9 ... =1&order=1
+1
And an excellent manuel.
See also this page: http://www.vectric.com/support/introduction-to-cnc.html. There is a link on this page for downloading an "Introduction to CNC" pdf.
Best regards
Didier
W7 - Aspire 8.517
johngreene
Model of CNC Machine: Legacy Maverick 3X5
Aspire Camp in the Pacific Northwest?
Post by johngreene »
I see where there is a "Aspire Camp" in South Carolina. Sounds great! Is there anything like this in the Great Pacific Northwest?
pvcsolutionsgroup
Model of CNC Machine: KWM
Post by pvcsolutionsgroup »
Hi,
Thank you,
PVC Solutions Group
15 Great Pasture Rd.
Danbury, CT 06810
https://pvcsolutionsgroup.com
High quality PVC trim boards at manufacturer direct prices.
