Re: Re: Version 9.0 is here. Upgrade Now!
- dwilli9013
works for me as it should. Version 9.008 Aspire
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- highpockets
Loads fine in V8.5 Aspire and VCarve, but I get an error loading in Aspire 9.008.
I'm beginning to think I should delete and reload Aspire 9.
- mtylerfl
Are you using Windows 7?dwilli9013 wrote:works for me as it should. Version 9.008 Aspire
- mtylerfl
What Windows version are you using?highpockets wrote:Loads fine in V8.5 Aspire and VCarve, but I get an error loading in Aspire 9.008.
- highpockets
Win 10 with all the latest updates
Window 10 Home version 1703
- mtylerfl
Hmmm. I wonder if only Windows 10 users are having the issue. Not saying Windows 10 itself is "at fault". Just curious if this helps isolate the issue somewhat.
- Model of CNC Machine: Shark HD4
Has anyone got it to work with V9 and windows 10? It looks like it works with windows 7 but not 10. I am also running windows 10
- highpockets
Michael, I was wonder if it's the Home addition of Win 10.mtylerfl wrote:Hmmm. I wonder if only Windows 10 users are having the issue. Not saying Windows 10 itself is "at fault". Just curious if this helps isolate the issue somewhat.
I've got windows 10, with the latest update. Aspire 9.008 throws an error when trying to import that 3DS file, while 8.5 opens it just fine.
- highpockets
What Level?4DThinker wrote:I've got windows 10, with the latest update. Aspire 9.008 throws an error when trying to import that 3DS file, while 8.5 opens it just fine.
Not sure what you mean by level? My 8.5 Aspire is 8.517. My V9 is 9.008. Tried again with 9, and using the icon on the modeling tab it generated a fatal error, while using the file:import option it just reports it could find no data in the file.
The .DMP file generated when it crashed is:
- VECTRIC20170727_2150.zip
- (25.13 KiB) Downloaded 142 times
- highpockets
Winver tells me it is Version 1703 (OS Build 15063.483) Windows 10 Prohighpockets wrote:Sorry, what Level is your Windows 10?
In can replicate the error on my system. Windows 10 Version 1511 (OS Build 10586.1007)
Has anyone been able to import a 3ds file with windows 10? I still haven't gotten anything from Vectric on my issue.
