change all start points
jeremysimmons
Model of CNC Machine: xcarve 1000mm
Post by jeremysimmons »
http://support.vectric.com/aspire-quest ... tart-point
http://support.vectric.com/aspire-quest ... f-toolpath
start points are usually in a corner. is there a gadget or another way to change all start points to a flat edge?
Re: change all start points
Version 9 has a new tab that lets you set the start point automatically for a toolpath.
jeremysimmons
that's better than a poke in the eye with a sharp stick. It only works about 80% of the time to accomplish what I need.
I asked because I want to avoid the dwell marks caused by some runout I was having.
I believe my problem is better solved by using ramps, which keeps the bit moving while it descends.
Best way to avoid dwell marks is to use in and out leads. That way the plunge and retract is away from the part.
PaulRowntree
Post by PaulRowntree »
Are you trying to re-orient the start points of a set of Vectors? GreenSquares gadget might help.
TreeSoft GreenSquares.pdf
(663.77 KiB) Downloaded 234 times
Paul Rowntree
