Trial version 3D
Trial version 3D
I have the trial version of Cut 3D and I go all the way through with designing the leaf relief plate in inches and when I put it in a post processor g-code sender it comes up in .54 inches by .36 inches for size of mill. I've tried different g-code senders and always the same. Am I not allowed toill this?
Re: Trial version 3D
At which point are you seeing those dimensions?
It shows up in my g-code sender like that. I tried 2 different ones and the same thing
Not sure what you mean by g-code sender? Are you using the correct post processor for your machine? Do the units match?
YYes I save the g-code files then open them in universal g-code sender to send them to machine. Thats where the discrepency happens
