Radius All Corners
- Vectric Staff
- Model of CNC Machine: 6040 Desktop CNC
Radius All Corners
Radius All Corners Gadget
This Gadget will allow you to apply a radius to internal and external corners on your selected vectors.
How to use:
1. Select vectors you wish to apply a radius to the internal and/or externals corners. If you wish to add a radius to a text object, you must first convert this to curves by selecting the text and selecting this option from the right click menu.
2. Go to Gadgets on the software's toolbar and select "Radius All Corners"
3. Decide whether you would like to add a radius to either the internal, external corners or both and enter the radius value you would like to add to each. If you only would like to add a radius to one set of corners, then leave the other set with a value of 0.
4. Press ok to run the gadget or cancel to exit.
The gadget will create you a new set of radiused vectors on a layer called "Radius Corners". The gadget will also colour these vectors orange to help differentiate between vectors. Please note you cannot undo the result of this Gadget which is why we do not replace the original vectors.
You can download the gadget from this link:
Link no longer active, please contact support.
How to use:
- scottp55
Re: Radius All Corners
Thanks Sean!
Well done Vectric and thank you for listening. I have loaded and tried this gadget and the radius function is just what I needed.
There is however a slight mod required or maybe I need some advise on how to better use Aspire.
Presently the gadget leaves the existing vectors there so maybe if there was a checkbox in the gadget that says "delete original vectors" could be added?????
Regardless, I am grateful for this gadget.
Excellent gadget & thanks to Vectric staff for listening.
Is it possible add a cheque box "delete original vectors"? or is there an easy way to do this manually?
GC
GC
thanks, I know I will use this a lot !
- Model of CNC Machine: High Z 720
Literally 1 hour before i saw this i did over 100 corners
Have tried this and i am sure i will use it as it worked great on my trial, thank you
VCarve Pro v9.012
High-Zs 720- Kress 1050 router ( CNC-Step DE version)
- ryadia
- Model of CNC Machine: 6040 USB CNC 4 axis Router/Engraver
Is there any chance this will work with version 9?
If not, is there likely to be a version 9 compatible gadget any time soon?
Ryadia
Ryadia
Assuming you have a previous installation if you copy the "Radius_All_Corners" folder from "Public Documents/Vectric Files/Gadget" folder for the 8.5 version to 9 then you'll have it working in 9.
- ryadia
Thanks Adrian. Does this apply to all/most Gadgets?Adrian wrote:Assuming you have a previous installation if you copy the "Radius_All_Corners" folder from "Public Documents/Vectric Files/Gadget" folder for the 8.5 version to 9 then you'll have it working in 9.
Ryadia
Yes, until the installers are updated to v9 that's the only way to use the gadgets from the gadget site that I know of.
- Model of CNC Machine: Industrial 8x4
Where can I find this Gadget?
I looked under Gadgets, with no luck.
- Model of CNC Machine: Home built cnc router using Masso G3.
Just curious.
Did you read the opening post of this topic?
I did not see that link.ozymax wrote:Just curious.
