Aspire 9: new clipart?
- volkhard
- Model of CNC Machine: Legacy Maverick
When I installed Aspire 8.5 I downloaded all clipart that came with it.
I just upgraded to V. 9. Is there new/ additional clipart that comes with it?
Legacy Maverick
Mach 3
Aspire V9
Sunny Florida
Mach 3
Aspire V9
Sunny Florida
- highpockets
Re: Aspire 9: new clipart?
Yes, look in your Customer Portal, scroll down to "your software, clipart and licenses"
I am now using the real V9 - How do you set-up the Clip art to update it. Are there any links to assist me and explain the process?
As John (highpockets) has said if you look in your customer portal it is there along with all your other clipart, its at the bottom of the list & named just look for V9 Installation is the same as all the other clipart, download & then when you open the file it will start the installer & install along with your other clipartDesert_Woodworker wrote:I am now using the real V9 - How do you set-up the Clip art to update it. Are there any links to assist me and explain the process?
Thanks for further info-
- volkhard
Thanks for the information. I still have a question: I found 2 files "V9 3D Tabs Clipart for Aspire" and "V9 Additional Clipart". I installed both successfully.
Am I right with my assumption that these clipart has been added into my already existing clipart folders as I don't see any new "additional" folders.
Sorry for my ignorance (or perhaps its my age??? ).
I just want to make sure I did it right while not knowing the exact former folder structure I had with Aspire V8.5.
Thanks again
Volkhard
Thanks again
Volkhard
Legacy Maverick
Mach 3
Aspire V9
Sunny Florida
Mach 3
Aspire V9
Sunny Florida
Yes the new clip art is distributed into the existing folders by category. There is another topic that will actually show you the new stuff. It might be under V carve topics.
Mark
Pioneer, CA
Pioneer, CA
Volkhard please never appologize for not knowing, for that's why we are here. I'll be posting 7-24 with V9 clip art questions. I noticed your machine setup- Your set to go- Best
If you downloaded & then installed following the onscreen instructions you get with the installer then yes you have installed it correctly, highpockets posted on this thread about what he had found new.
http://forum.vectric.com/viewtopic.php?f=27&t=27725
- Vectric Staff
- Model of CNC Machine: xxx
We have included $500 worth of FREE Design & Make clip art with all upgrades to Aspire V9.
To see what's included check out the PDF attached.
- Free D&M Clip Art with Aspire V9.pdf
- (470.87 KiB) Downloaded 467 times
My method for getting the clip art to "appear".
Since I have 8.5, I only want the 2 additions, V9 bonus and 3d tabs- I download each one seperately and go through this process, individually. I "open" the new download to kickstart the installation for it to appear. The file appears on my computer, at the lower left part of the screen. Click on the download and open it. It will prompt you to continue.... When it is finished, exit and reload- Magic it appears.
