Here's something I can't believe I never had to do before, seems like it should be easy but I can't find out how.
Can't post pictures right now but if needed I will later.
So take a simple rectangle, say 1" x 3", and click "create a shape" with it selected. choose the dome shape at +90 and the arced portion will be along the 1" side with a slight arc at the ends of the 3" side.
I need the opposite. Need the full arc to be along the 3" side. How do I do that? I feel like I'm missing something very simple but can't see it.
Reverse direction of a component
- dealguy11
Re: Reverse direction of a component
Not really getting what you're wanting. When I follow the technique you describe, this is what I get. There are arcs both at the ends and the sides. What you you want different?
- dealguy11
I made a couple of guesses about what you might want. Are either of the new shapes what you had in mind? They're made with 2-rail sweeps. Instead of starting with a rectangle, you'd use either the short or long sides of the rectangle as rails, and make an arc for the sweep.
That's the one at the bottom!dealguy11 wrote:I made a couple of guesses about what you might want. Are either of the new shapes what you had in mind? They're made with 2-rail sweeps. Instead of starting with a rectangle, you'd use either the short or long sides of the rectangle as rails, and make an arc for the sweep.
I knew I was missing something easy.
Thanks.
