stepover percent during final finish
- Model of CNC Machine: TinyG - Homemade
So I watching videos on cutting models and I am still confused on editing the ball nose bit to 8 - 12% But another
video says 14%.
So if I understand that this is the distance that the ball nose cross over the path when cutting the 2.5d model in order
to keep the finish smooth but having the x% cross over.
Do I understand that correctly?
video says 14%.
Re: stepover percent during final finish
Yes.So if I understand that this is the distance that the ball nose cross over the path when cutting the 2.5d model in order
If you have used a lawn mower you may recall that you have to overlap as you go back and forth so you ensure all the grass gets cut. Think of the stepover as what percent of the width do you move over for each pass.
The smaller the stepover the less likely you are to see ridges or lines in the final finish. However, a smaller stepover increases machining time.
I am really anal sometimes but on finish passes where I want a fine finish, no ridges, and no sanding I will set my stepover as low as 3-5%
Roughing is a different story.
The picture Randal posted is a REALLY good example.
Thanks guys. Its funny I was thinking of the lawn mowing example to explain this. Thank you for posting the graphic that really helped. So is 3 - 8% a good number to use? Or is there a rule
based on the size of the ball nose I use?
I finished 3 test small pieces and it really worked out on #2 and #3 as soon as I figured out the boundary offset settings.
Thanks again.
Thanks again.
I prefer 8%
YMMV
YMMV
- Xxray
I usually go with 14% using a .03125 bit ... Have tried 8% with no discernible difference to the eyeball.
There is no rule of thumb here.
It's all a matter of personal preference and what the desired outcome is.
What is good to one person may not be good to another.
That does not mean anything is correct or incorrect.
It's just a matter of what makes you happy.
The stepover ridges could be laid out to see the ridges, but there will be ridges even if you cannot feel them.
The smaller the stepover the smaller the ridges.
At a 2% stepover the ridges are so small that they are almost not there.
Then it also depends on the diameter of the ball nosed end mill.
The larger the diameter, the flatter the nose of the end mill will be.
The smaller the ridges and the more forgiving the stepover is.
Another thing to consider is time. If a job is going to run for 4-5 hours and I am just putting around the house and yard and I can pop in to check on the machine - I don't care that it took a long time.
On the other side of the coin, if I have a 5% stepover and the finish is going to take 18 hours and I am not going to be watching it, I will adjust the parameters to get a reasonable cut time and compromise of the quality
Personally, I just hate a fixed rule of thumb.
I find it better to understand and adjust according to my needs or desires.
Like I said - I can be very very anal about this stuff.
I can tend to be a bit less practical.
- Model of CNC Machine: shopbot desktop
Great description, very clear.
Very good description Leo, I second that.
I will set the step over a little higher depending on the models detail. Sometimes its not that much difference for the time it takes.
I dremel tool with a proper sanding mop that's about 220 grit can makes some pretty fast sanding but you have to be careful not to sand out wanted detail.
Mark
Mark
I keep hoping Dremel will add an undo button to the tooldremel tool with a proper sanding mop that's about 220 grit can makes some pretty fast sanding but you have to be careful not to sand out wanted detail.
- sharkcutup
Using a .09375 radius .1875 dia ballnose with 10% (.0188") step over this Moose Model came out rather well - little light sanding to no sanding is all that is needed!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
