Join Open Vectors
jakumins
Model of CNC Machine: Shop Bot
Join Open Vectors
Post by jakumins »
I was wondering if anyone has created a gadget to join open vectors or knows if there is a lua function to do so?
CrowsWW
Model of CNC Machine: ShopSabre 4896
Re: Join Open Vectors
Post by CrowsWW »
if you have Vcarve Pro it is on the Edit Objects.
see picture I put a red line around the icon.
Troy Crow
Crow's Woodwork's
I have a day job to support my wood habit!
jakumins
Post by jakumins »
Yes I know how to do it manually, but I want aspire to do it for me via a gadget.
jakumins
Post by jakumins »
I guess let me clarify, I am looking to make a gadget that selects all vectors on a layer, joins the vectors then selects the next layer....and so on.
Post by Rcnewcomb »
You would need to write your own based on your rules for how vectors should be joined.
For example, The vectors may be joined, but not be what you had in mind.
jakumins
Post by jakumins »
The shapes I would be joining would be simple closed (not recogonized by aspire as closed) shapes, with a tolerance less than 0.01 in.
My question basically is what lua script function can I use to join the vectors?
There isn't one function that will do it. As Randall says you have to write code that uses a series of different functions to do it even if all you want to do is what you describe. Basically working through the contours, finding the gaps, appending onto a new vector with the points adjust to be the same etc. That's the only way I know to do it.
I use scripts to automate the Aspire UI itself when I want to do something like that as it's quicker and easier than creating the LUA code.
jakumins
Post by jakumins »
Thanks Adrian!
That's kind of what I was thinking, I was just hoping there was an easier way.
reggieaj
Model of CNC Machine: X-Carve
Post by reggieaj »
Adrian,
That's the approach I'll take.
Since the elements I want to join will always be connected unless they are closed objects (such as holes) within the perimeter of the the objects that need joining, I expect the following algorithm would work:
Create new empty contour
Add 1st encountered non-closed element to the contour
For each remaining non-closed element
Append the next element to the end of the contour
This assumes appending to a contour results in a join. And I would expect traversing the elements should show that they are encountered in adjacent/connected order.
I'm going to try to modify the SelectVectorsOnLayer function to accomplish an overall join of the non-closed but connected elements on a layer.
What say yee?
