I am new to PhotoVcarve and been looking at tool selections. I looking at using a 1/16 ball taper bit. I be
cutting to Walnut in the 10" X 12" size.
I seen some use 60 Degrees also. What are the thought process for 60 degrees vs 1/16 or 1/32 ball tapers?
Any experienced advised would be helpful.
tools for PhotoVcarve?
Re: tools for PhotoVcarve?
If you are going to be doing photographs I think you will find that walnut is too dark for good results. For photos select a light colored wood with minimal grain such as hard maple.cutting to Walnut
a V-bit that comes to a sharp point will allow for greater detail, and they tend to be less fragile. (my opinion)I seen some use 60 Degrees also. What are the thought process for 60 degrees vs 1/16 or 1/32 ball tapers? Any experienced advised would be helpful.
- Model of CNC Machine: TinyG - Homemade
Thanks.
I try that.
I try that.
