The all time great topics from elsewhere on the forum
Postby Mike-S » Fri Mar 03, 2017 7:28 pm
In Mach 3, try checking 1/2 pulse Sherline.
Mike-S
Postby ger21 » Fri Mar 03, 2017 8:44 pm
Mike-S wrote:In Mach 3, try checking 1/2 pulse Sherline.
That won't have any affect with the Smoothstepper.
Try reducing your acceleration and velocity in motor tuning.
Gerry
ger21
Postby Azulikit » Sat Mar 04, 2017 3:42 pm
I will try that but I don't understand why this would happen at first every once in a while now every time I run it
Azulikit
Model of CNC Machine: homemade
Postby Azulikit » Sat Mar 04, 2017 5:18 pm
Gerry
I changed the speed and velocity and had no change . It still stopped briefly while the g-codes are still reading.
Thanks for the help
Ken
Azulikit
Postby bertvanderhulst » Sun Apr 09, 2017 5:33 pm
Hello all,
I am relative new to cnc,i built my first machine together with a friend, and we used Mach3 ,but since a few week i have a Oliver 1015 and use V-carve desktop.
My question is, can i use g code files created in Lazy-cam for Mach3 ( these file have been saved as "tap" files)?
If i am correct i cannot open a "tap" file in V Carve, Maybe a stupid question but can i just rename a "tap" file to and safe it as a "nc" file to be used in V Carve?
bertvanderhulst
Model of CNC Machine: Oliver 1015
Postby Adrian » Sun Apr 09, 2017 5:46 pm
You can't load a gcode file into VCarve.
VCarve (via the selected post processor) creates gcode files that you load into Mach3.
Postby PsychFarDigest » Thu Apr 13, 2017 8:16 am
well. i met a similar problem and i found the answer from this thread :lol:
PsychFarDigest
Model of CNC Machine: Diy Tool Cnc Metal Motorized Mini Lathe
Postby adam_m » Tue May 09, 2017 4:36 pm
Having a problem viewing the forum at home... possibly IP is banned?
I'm not sure whom to ask about the problem... just a trial user.
adam_m
Model of CNC Machine: Home made
Postby adam_m » Thu Jun 01, 2017 9:42 pm
I'm still trying to get my IP un-banned from the site, anyone can help?
I'm pretty sure it happened when my account somehow got nuked...
adam_m
Postby Adrian » Fri Jun 02, 2017 7:05 am
See if your IP is blacklisted anywhere (https://mxtoolbox.com/) most forums subscribe to at least a couple of those blacklists to detect spammers and if the IP you've been allocated via your ISP used to be one of those that could be the problem.
Postby adam_m » Fri Jun 02, 2017 2:56 pm
Thanks for the reply Adrian, I assumed it was the site since I'm able to do the same on my webserver.
So, they don't blacklist IP's or ban them?
Also check the blacklist and its all good...
adam_m
Postby Adrian » Fri Jun 02, 2017 3:16 pm
adam_m wrote:So, they don't blacklist IP's or ban them?
No idea, the forum is primarily for user to user support. You'd need to contact vectric directly to get an answer to a question like that.
Postby nstrong » Sun Jul 02, 2017 5:53 pm
I am planning to upgrade to vcarve pro so I can use the dove tail gadget. is it possible to have one side be a blind dovetail? If so do I increase the board width for the blind side, or adjust the depth of cut
nstrong
Model of CNC Machine: piranha fx
Postby gutzy » Tue Jul 25, 2017 3:20 pm
Error message....
I am getting an error message:
target position / positive SW end (G00,G01)
X axis program number -1
blocknumber N 3790
I imported a drawing and set the tool path with no issues and this is the error message I get when I try to start my project. Any advise on fixing this error?
gutzy
Model of CNC Machine: Laguna Smartshop 2
Postby Adrian » Tue Jul 25, 2017 4:38 pm
That's not an error from a Vectric program though is it? Looks more like an error from your controller software.
PreviousNext
Return to Technical Archive
