Does PhotoVCarve carve machine relief models?
huntleybill
Model of CNC Machine: Home Built
Post by huntleybill »
I am trying out PVC but I can't seem to get good results. When I use PVC I get a nice looking image of my Beagle. But when I send it to my CNC I get very bad results. As seen in the pictures. I can't even tell what it is I just machined out.
The 3rd picture is What I would like to do. Except put the image of the dog in place of the fish. Am I doing something wrong or is PVC not the right software? If PVC is not the right software, can you recommend the right software?
Thank you for your time.
Bill
Re: Does PhotoVCarve carve machine relief models?
Ideally you need VCarve (to machine existing 3D models) or Aspire (to create your own) but PVC can do relief cutting if it has a picture in the right format.
See here for more details and links - http://forum.vectric.com/viewtopic.php?f=7&t=18336
FixitMike
Post by FixitMike »
For a linear halftone, (not 3D):
I use a Carving Max Depth of .05 and a line spacing of 110%. The attached picture was done with a 45 degree V bit.
You need to apply a sealer to the image, and then fill the carved lines with paint. I use black acrylic. Wipe off the excess with a damp cloth. After the paint dries, sand off any excess that is left on the surface. The image will pop out.
Gracie3.pvc
(1.82 MiB) Downloaded 247 times
dwilli9013
Post by dwilli9013 »
Very Nice Mike,
I've learned a new technique that I will certainly have to try.
D-Dub
Dwayne
Dwilli
huntleybill
Thank you Adrian. What format should the image be in for PVC to work?
It's not something I've done myself but all the detail are in the link I posted.
