Hello,
i was thinking is there a site on the web where i can get the wingribs Profil to get them done with CNC?
So just pick the Profil copy and past it in my CNC program Change the size and start!!!!!!
i hope to get some help.
Terry
Profil for wingribs
- Model of CNC Machine: home built shopbot clone. CNC lathe
Re: Profil for wingribs
are you using a Hotwire cutter?
Don
Don
@ Mike S Thanks for the tip NACA airprofil will look that up.
@ Don No i am using a Stepcraft 840 CNC milling Milling Maschinen
Depending on what you want to do, the 2D CSV gadget lets you build them directly in VCP or Aspire.
Paul Rowntree
