does someone have the post processor file for a Biesse Rover 30 ... please
thanks to all of you...
Need Help: BIESSE Rover 30 post processor
- Model of CNC Machine: biesse rover 30L2
Re: NEED HELP : BIESSE Rover 30 post processor
Hello folks, i have read the Vectric post processor guide and i am a newbies in this domain ... what is the problem i face and how to fix it , maybe its gonna be more easy that way ...
the tool changing ... how to program the tool changing ... i have the automatic tool changing from 1to 7 positions ...
and the rapid move ... i find my machine move to much fast between each operation ...
of course if someone already work with a Biesse Rover 30 L2 1999 , if this person can send me his post processor file i can study directly the post processor , because i also want to understand what i am doing ...
thanks
frank131313''at''hotmail.com
thanks
Do you have any sample code that runs on your machine?
That's the best place to start.
Have you done a search on the forum? There are lots of threads about the Biesse and the problems with getting it to work and some solutions.
yes => but its like i am not able to upload so i do that way ...ger21 wrote:Do you have any sample code that runs on your machine?
PARAMETRI=000000227
UTENSILI=000000338
LABELF=000001586
LABELC=000001573
FORATURA=000001540
CONTORNATURA=000000357
TABELLEFORI=000001555
CONFASSIST=000001599
ATTREZZAGGIO=000001616
[PARAMETRI01]
N10 G71 HC=1 LY=876.3 LZ=37.30 FIL=1 BLO=0 ACC=0 RUO=0 PRS=1 PRL=1 PLPZ=46 KA=1.000 LX=1968.5
[UTENSILI01]
PN1
[CONTORNATURA01]
N100 QX=984.25 QY=LPY QZ=LPZ/2 PRF=50 VF=.5 TH1 L=G2
N110 QX=167.46 QY=0 QZ=19.62 PRF=6 VF=2 TH2 L=G4
N120 QX=193.67 QY=0 QZ=9.58 PRF=6 VF=2 TH2 L=G4
N130 QX=218.26 QY=0 QZ=9.58 PRF=6 VF=2 TH2 L=G4
N140 QX=244.47 QY=0 QZ=18.78 PRF=6 VF=2 TH2 L=G4
N150 QX=946.15 QY=0 QZ=19.62 PRF=6 VF=2 TH2 L=G4
N160 QX=971.55 QY=0 QZ=9.58 PRF=6 VF=2 TH2 L=G4
N170 QX=996.13 QY=0 QZ=9.58 PRF=6 VF=2 TH2 L=G4
N180 QX=1020.74 QY=0 QZ=18.78 PRF=6 VF=2 TH2 L=G4
N190 QX=1724.02 QY=0 QZ=18.78 PRF=6 VF=2 TH2 L=G4
N200 QX=1749.42 QY=0 QZ=9.58 PRF=6 VF=2 TH2 L=G4
N210 QX=1773.22 QY=0 QZ=9.58 PRF=6 VF=2 TH2 L=G4
N220 QX=1800.22 QY=0 QZ=18.31 PRF=6 VF=2 TH2 L=G4
N20 PAN=1 ST1="PN1" ST2="NULL" L=PCUA ; ANT TC="A"
N30 ; Z=PRK
;N40 G46 X-31.62 Y-31.63 G41 F10.00 S18000 VF=2.00 TP1 PRF=40 L=PON M55 TRZ=0
;N50 G1 X3.17 Y3.17
;N60 G1 X3.17 Y879.48
;N70 G1 X1971.67 Y879.48
;N80 G1 X1971.67 Y3.17
;N90 G1 X3.17 Y3.17
;N100 G1 X-31.62 Y-31.63 G40
;N110 G0 L=PSU
yes i have do ... before asking ...Adrian wrote:Have you done a search on the forum? There are lots of threads about the Biesse and the problems with getting it to work and some solutions.
Nobody here can help with the tool changing code for a Biesse Rover 30 XNC controller ?
You should contact support@vectric.com
The forum is primarily for users of Vectric software to help each other out. Unless another user has your machine and is monitoring the forum you may not hear much.
Re: Need Help: BIESSE Rover 30 post processor
i know ,but my machine was popular and still continue to be , so i keep hope , cause now i just need to understand the tool changing code of the post processor ... the rest i have been able to fix ...
If you've read the other Biesse threads on the forum you'll know that others have the same problem and no-one has come up with a solution that they are willing to share (if one exists). All the suggestions that have been made on the other threads are correct as far as the Vectric side of things is concerned but for some reason the Biesse software doesn't work with those settings.
