Balancing/area gadget
Postby Kayvon » Sun Feb 19, 2017 5:39 pm
This is a gadget I wrote for balancing clock hands. It can be used to determine the total area of an object and tell you how balanced the object is left-to-right. Usage is simple:
  • Highlight the object to want to balance
  • Rotate the object so it's balancing left-to-right
  • Move the object so its pivot is at x=0
  • Run the gadget
Balance_Gadget.zip
Balance/area gadget, v2017.02.19
(2.34 KiB) Downloaded 308 times
Kayvon
Re: Balancing/area gadget
Postby Rcnewcomb » Sat Feb 25, 2017 12:24 am
Thanks for sharing
Postby Nthkentman » Fri Mar 24, 2017 11:13 pm
Kayvon wrote:This is a gadget I wrote for balancing clock hands. It can be used to determine the total area of an object and tell you how balanced the object is left-to-right. Usage is simple:
  • Run the gadget
Silly question.. after unzipping the gadget how do you import or install it into V Carve 8.5?
Nthkentman
Model of CNC Machine: Emach EM900. KEW 1212
Postby slowoodworker » Sat Mar 25, 2017 12:18 am
Oh, don't say that. I'm looking for the same answer.
--Rich Farwell
slowoodworker
Model of CNC Machine: CNCRouterparts Desktop Pro
Postby highpockets » Sat Mar 25, 2017 12:29 am
slowoodworker wrote:Silly question.. after unzipping the gadget how do you import or install it into V Carve 8.5?
--Rich Farwell
Make note of where you unzipped the gadget.
In VCP or Aspire click on File->Open Application Data Folder
A Windows Explorer window will open to VCP data folders.
Click on Gadgets.
Copy the Balance_Gadget.lua into the Gadgets folder.
Close Explorer window and restart VCP.
Postby Nthkentman » Sat Mar 25, 2017 11:33 pm
Cheers for the info... Will have a play tomorrow
Nthkentman
Return to Gadgets - Releases
