Balancing/area gadget
Kayvon
Post by Kayvon »
This is a gadget I wrote for balancing clock hands. It can be used to determine the total area of an object and tell you how balanced the object is left-to-right. Usage is simple:
  • Highlight the object to want to balance
  • Rotate the object so it's balancing left-to-right
  • Move the object so its pivot is at x=0
  • Run the gadget
Balance_Gadget.zip
Balance/area gadget, v2017.02.19
(2.34 KiB) Downloaded 530 times
Re: Balancing/area gadget
Post by Rcnewcomb »
Thanks for sharing
Nthkentman
Model of CNC Machine: Emach EM900. KEW 1212
Post by Nthkentman »
Kayvon wrote:This is a gadget I wrote for balancing clock hands. It can be used to determine the total area of an object and tell you how balanced the object is left-to-right. Usage is simple:
  • Run the gadget
Silly question.. after unzipping the gadget how do you import or install it into V Carve 8.5?
slowoodworker
Model of CNC Machine: CNCRouterparts Benchtop Pro
Post by slowoodworker »
Oh, don't say that. I'm looking for the same answer.
--Rich Farwell
Post by highpockets »
slowoodworker wrote:Silly question.. after unzipping the gadget how do you import or install it into V Carve 8.5?
--Rich Farwell
Make note of where you unzipped the gadget.
In VCP or Aspire click on File->Open Application Data Folder
A Windows Explorer window will open to VCP data folders.
Click on Gadgets.
Copy the Balance_Gadget.lua into the Gadgets folder.
Close Explorer window and restart VCP.
Nthkentman
Cheers for the info... Will have a play tomorrow
