Hi, I'm working on a post for a Komo Innova. It has a Fanuc 210-MB control and an 8 station tool changer.
The problem I'm having arises from the fact that the way the control is set up, the tool offset register is the tool number plus 10. I tried changing:
"[N]G00G43H[T][ZH]"
to:
"[N]G00G43H[T+10][ZH]"
and of course that failed, but that's what I need to achieve.
Any help would be gratefully appreciated.
tool offset on Komo Innova
Re: tool offset on Komo Innova
I actually don't even have to do any arithmetic. All I have to do is figure out how to insert the numeral "1" in between "H" and the variable [T].
Try this:I actually don't even have to do any arithmetic. All I have to do is figure out how to insert the numeral "1" in between "H" and the variable [T].
"[N]G00G43H1[T][ZH]"
The first time I tried that it didn't work. I must have bungled something, because it works now!
