Hello!
I've been trying to cut simple shapes out of curved surfaces, and get poor cut quality most of the time.
To experiment, I've used different post processor's (arcs vs normal etc), I've run the same profile cut but NOT projected to the mold, I've slowed it down, I've simplified the vectors with circular arcs and bezier arcs, and tried cutting ON the vector instead of OUTSIDE the vector.
So far, the only combination that gives me any luck is ON the vector, and NOT projected onto the mold. I could get this to work to cut out the parts, but it would be faster and cleaner if I could cleanly map the toolpaths to the 3D shape.
Based off what I've seen, it seems Aspire is somehow coding things in a way that creates jerky motion, and low quality edge finish of parts. I've briefly looked through the shopbot code and don't see any real differences between a clean running code, and a jerky one.
Any ideas or help on this?
Weird movement when projecting toolpaths to molds
- Model of CNC Machine: Shopbot Alpha 4848/Homebuilt 2475router
Re: Weird movement when projecting toolpaths to molds
Without seeing the file it's hard to say...
Here's an example of an unexplainably jerky fileAdrian wrote:Without seeing the file it's hard to say...
And I added the smooth cutting file, with no Z movement
- Torus - cutout ARCS - circular.txt
- Jerky movement along ~50% of the cut
- (45.18 KiB) Downloaded 174 times
- Profile 1 - on cut - smooth.txt
- Smooth cuts, no z
- (28.85 KiB) Downloaded 176 times
Can you post the Aspire file?
We figured out what it was! Our Shopbot settings under VR (ramp speeds) needed a much higher "3D Ramp Threshold Setting" and a lower "Minimum Distance to Check"... essentially the MDC value was causing the machine to try and slow down at variations too small to matter, and ruining the piece. Now it ignores those tiny variations and stays at full speed
Thanks for your responsiveness!
