Perhaps I'm not using the correct key words or search options.... I'm looking for a Post Processor for Photo Vcarve in order to send carve jobs to my X-Carve through Easel.
if I've missed something that was already posted, I apologize. I am already running VCarve Desktop on my system and successfully exporting G-Code to Easel, can I use the same PP file for PhotoVCarve?
any help is appreciated.
I've searched and searched
Re: I've searched and searched
See this thread: Guide to editing a Vectric Post Processor
- IslaWW
capraun...
IF you cannot find a post for PVC, you may want to check with your machine mfgr or Vectric support.
If that doesn't pan out, copy the post you use from VCarveDT into the postP folder for PVC. Open PhotoVcarve. You will most likely receive an error message. Using the Editing Guide Randall links to above, remove the line, lines or section that returns the error. Save the post and reboot PVC. Repeat as needed. It may take multiple tries, but it will work.
The PostP editing guide is accessable from the help menu of VCDT. There is a section listing which commands are not supported by PVC.
GCnC Control
GCnC Control
- Model of CNC Machine: Inventables X-Carve
Thanks much.
Per your guidance I've copied the Vectrics-Easel PP from VCarveDT to the PVC PP folder and calculated a toolpath and saved. I did not run into any errors while saving the toolpath, so I will push it through the Gcode sender this evening to see what comes out.
- adze_cnc
For the thread Randall linked to remember that the document on your computer is quite likely more up to date than the one linked in the post.
Steven
Steven
Just email Vectric support they will send the information to you by email. I have a swift 4 x 4 from Luguna Toools and Photo v carve did not list it. They were quick to respond. But remember they are in a different time zone.
