A toolpath of a simple profile of a box only produces a line cut along the X axis. The first problem seems to occur at N260, the A- move. It appears that Mach just ignores it, as there's no delay on the X axis moves. Same for the A+ move in N280. I can manually move the A axis with the hotkeys and the pendant, and A axis commands prior to line 260 will cause the the table to move into correct position.
Anyone have any ideas?
Code: Select all
( Box1YtoA )
( File created: Thursday May 05 2016 - 09:50 AM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 4.000, Z= 0.688)
( Diameter = 1.3760 Inches)
( Y Values are wrapped around the X axis )
( Y Values are output as A )
(Toolpaths used in this file:)
(Box1)
(Tools used in this file: )
(1 = End Mill {0.250 inch})
N130 G00G20G17G90G40G49G80
N140 G70G91.1
N150 T1M06
N160 G00G43Z2.0000H1
N170 S12000M03
N180(Toolpath:- Box1)
N190()
N200 G94
N210 A0.0000 X0.0000 Z2.0000 F100.0
N220 G00 X-1.0000 A83.2787 Z0.9380
N230 G00 X-1.0000 A83.2787 Z0.6880
N240 G1 X-1.0000 A83.2787 Z0.5510 F30.0
N250 G1 X1.0000 A83.2787 Z0.5510 F100.0
N260 G1 X1.0000 A-83.2787 Z0.5510
N270 G1 X-1.0000 A-83.2787 Z0.5510
N280 G1 X-1.0000 A83.2787 Z0.5510
N290 G00 X-1.0000 A83.2787 Z0.9380
N300 G00 Z2.0000
N310 G00 A0.0000 X0.0000
N320 M09
N330 M30
