Need help cutting small letters
- scottp55
Re: Need help cutting small letters
Martin, Your signmaking background is showing:)
Sometimes we're just happy it cut and was an improvement
Good constructive comments!
HP, Looks good, but looks like last dark coat is bleeding a lot?
I seem to remember after carving that most people with good clean results I've admired, are giving one(or more) thin coats of clear to the now bare wood to prevent that.
Possibly changing from a penetrating oil like Watco, to maybe a gel stain and and a quick wipe off...or even a paint might be better?
Feels good when it's tiny and cuts clean...Doesn't it?
- highpockets
Martin,
Never said you against MDF. I appreciate you reminding me that MDF is hard on bits.
Thanks for the great critique, I'll work on the layout a bit. Most of the placement was copying the original Las Vegas sign. I guess I can fudge a bit and who would know. I'm also changing the lettering over to VCarve.
Wish I had your access to good wood and the room to put it. I'm a bit cramped for space so I have to plan a project get just enough wood to do the project and move on.
- highpockets
Scott,
You nailed it, I'm just so happy to get clean cut small letters I can't see straight
I didn't seal the wood after carving, I just applied the Dark Walnut and got lots of bleeding. My next test will include a sealing coat of shellac before applying either a gel stain or paint. I've had good luck with just sealing then painting to produce a crisp clean lettering.
The amazing part about cutting these small letters is the scrap wood I used. It's Aspen, untreated it looks like a shaggy dog after carving. I used it on the signs I made for the "Relay for Life" project. Took for ever to clean up and sand. Never again. Finishing the wood first then carving made all the difference in the world. Still won't use Aspen again though
Thanks guys for all your help!
- highpockets
Here's the new layout. I like it a lot better. It pops.
Martin, I worked on the letters just a little bit. Thanks.
- scottp55
New lay out looks much better!
For stubborn Maple fuzzies, a good stiff bristle brush,or a bamboo skewer works great.
For the most part the denser, close grained, SMALL pored wood are best for teeny stuff.
Try giving his 30degree bits a shot at tiny 3D stuff like those 1.25" Moose also:)
- highpockets
Scott,
Once you prep the wood and carve the text etc, what do you put on the text and carving to keep it from bleeding when you apply a fill color to the text etc?
I did a test prepping the wood with Watco Danish Oil, carved the test text then wiped on some more Danish Oil. I then used some paint to color the text. The paint soaked into the finish and some bleeding in on the edges of the text. I had to sand the surface again to get rid of the paint on the surface around the text.
There has to be a better way.
- scottp55
Can't help you much there, as I'm a straight oil guy by nature, and normally get enough contrast by the end grain soak up.
There have been quite a few threads on bleeding avoidance. I think If I were doing it I might try a couple coats of a dewaxed shellac(ZZinser sanding/sealer?) as shellac will stick to most anything and vice versa.
Seem to remember people getting decent results with acrylic paints/stencil paint/and others. and then sanding or immediate wipe off.
Google this forum and then search terms and stuff should pop up.
Hopefully someone who infills will pop up and chime in.
Sorry no help:(
Sorry no help:(
I'm the same as Scott, just used oil to finish & not done any paint infills yet although I keep saying I must try it at some point. Here is one thread to get you started, there are quite a lot on the topic if you try a search on the forum
http://forum.vectric.com/viewtopic.php? ... xt#p161308
- highpockets
Thanks Martin, I've read this and several other threads on the subject and I've had pretty good luck with them (when I've done the correctly). Just have never used Watco Danish Oil on a carved project before and my first attempt at coloring the letters had some minor bleeding (probably that only members of the forum would notice). Just trying to improve my skills.martin54 wrote:I'm the same as Scott, just used oil to finish & not done any paint infills yet although I keep saying I must try it at some point. Here is one thread to get you started, there are quite a lot on the topic if you try a search on the forum
- highpockets
Scott,scottp55 wrote:Can't help you much there, as I'm a straight oil guy by nature, and normally get enough contrast by the end grain soak up.
Sorry no help:(
I'm working on some test pieces right not, before screwing up the real deal. Having just a little bleeding issue after carving and adding more Danish Oil. Your stuff comes out so great I just figured you had all the answers ;-}
Acrylic paint might not be the best choice, may try something like a stencil paint or may be some gel stain, been wanting to get some to try.
- scottp55
I played with a Cherry gel stain after seeing CarveOne and Randall's work, but Cherry wasn't the right choice, and I think I only had 2 coats of Linseed on the hard Maple and had the same problem as you so stopped playing.
Plan on picking up some General Finishes Java gel stain(CarveOne uses it a lot) in future to experiment with Glazing Maple 3D's, but will probably go my full 3 coats, and then LIGHTLY apply and immediately wipe off 3D's and reapply as needed for effect.
NOT very good at it, and not really my style, but I'll play with it.
I used a Franklin gel and wasn't really happy.
Read the other threads and look at pics and methods.
I'm a newbie at the effect you want:)
- Model of CNC Machine: Home made
You can seal the letters with either the shellac or even poly. Just make sure to get enough coats to completely seal it. Then paint and done. I always use a mask so I can just peel it off and paint it without worrying about being neat. Works every time for me.
- highpockets
It's been a while since I started this project and several life events have gotten in the way, but now it's finished and the bride is happy, which is all that matters.
Thanks to everyone for all the help.
- Model of CNC Machine: XCarve
Hi Highpockets,
I'm trying to do something similar to what you're doing, and I see that I even have the same bit as you. At one point you mentioned that you got success following Scott's suggestions, but from my reading carefully over the thread it's not exactly clear what feeds/speeds/depths you used.
I'm looking to replicate your success.. any chance you would be able to tell me:
-Feeds/speeds (guessing IPM 30/15 for feed/plunge 16k for speed?)
-Depth of cut
Any advice on wether this is a fool's errand with plywood ?
-Depth of cut
- highpockets
Here's a little fun project that will give you all the information on setting.
http://forum.vectric.com/viewtopic.php? ... ken+dinner
Look at the 5th post, I posted the CRV file
Hope this helps....
Hope this helps....
