HELP...My Text Mirrored???
mfirlott
Post by mfirlott »
Hi everyone!!! I need TEXT help....
Working on a 3-piece walking stick using my recoil and the first piece has my wife's name (Lucie) engraved with a 60 degree v-bit going around the shaft. In both the flat and wrapped views after I run the toolpaths, the text seems normal. But after the job completed, her name was reversed, like in a mirror???
Was I supposed to reverse the text? It shows perfect on the previews??? And what if I do the text running vertical along the shaft?
Thanks...se pics below...
V-bit Settings
V-bit Settings
Unwrapped toolpaths
Unwrapped toolpaths
Wrapped toolpaths
Wrapped toolpaths
Final Output from CNC
(Mitch)
CAMaster Stinger I
Vectric Aspire
Epilog 45watt Helix Laser
IslaWW
Re: HELP...My Text Mirrored???
Post by IslaWW »
Mitch...
We need to get your rotary going in the proper direction. Email me (address in profile)
GCnC Control
mfirlott
Post by mfirlott »
PM sent. Thanks for the help.
(Mitch)
CAMaster Stinger I
Vectric Aspire
IslaWW
Post by IslaWW »
Mitch..
Nothing received. Email to gcnc411@gmail.com
GCnC Control
mfirlott
Post by mfirlott »
Email sent. Thanks again for the offer to help.
(Mitch)
CAMaster Stinger I
Vectric Aspire
Frunple
Post by Frunple »
You should look a little closer, the whole thing is reversed not just the text.
Easy fix, I'm sure IslaWW will get you going.
mfirlott
Post by mfirlott »
LOL. Now that you mention it I see that the frog is facing the wrong way!!!
Thanks for pointing that out.
(Mitch)
CAMaster Stinger I
Vectric Aspire
mfirlott
Post by mfirlott »
Wow....as usual...what fantastic support from this forum. Gary Campbell walked me through a wincnc.ini edit (I saved the original of course) that fixed the counterclockwise rotation. All is good now. Thanks Gary!!!
Also thanks to IslaWW for also reaching out to help.
Wow!!!! What a resource this forum is.
(Mitch)
CAMaster Stinger I
Vectric Aspire
Frunple
Post by Frunple »
mfirlott wrote:Wow....as usual...what fantastic support from this forum. Gary Campbell walked me through a wincnc.ini edit (I saved the original of course) that fixed the counterclockwise rotation. All is good now. Thanks Gary!!!
Pretty sure they are both the same guy.... I just know it!! Like Clark Kent and that guy in the blue tights.
mfirlott
Post by mfirlott »
Ha!!! That's potentially hilarious if you're right. Either way...I like them both...or just him maybe...who knows...only the Shadow Knows... :twisted:
(Mitch)
CAMaster Stinger I
Vectric Aspire
IslaWW
Post by IslaWW »
Now that's comedy!!! :P
One in the same Mitch... Glad you are up and running
GCnC Control
mfirlott
Post by mfirlott »
Thanks again Super Gary!!
Ran a test later and rotation is clockwise and text is readable...left to right. Beauty!
The world is good once again thanks to that masked stranger.
(Mitch)
CAMaster Stinger I
Vectric Aspire
4DThinker
Post by 4DThinker »
If the problem shows up again just place the finished object next to a mirror. The reflection will look correct. ;)
4D
garylmast
Post by garylmast »
I once had the same problem. I had the motor end (head) of the rotary sitting at the foot of the CNC bed and was turning counterwise, so I rotated it end to end, so it would sit at the foot end of the bed, making it turn clockwise. Problem solved. Gary
mfirlott
Post by mfirlott »
LOL...I should of done that too. Winch is still in the ceiling. Could of lifted then turned the entire CNC end-to-end. :lol:
(Mitch)
CAMaster Stinger I
Vectric Aspire
