Joypad
Lameiii
Model of CNC Machine: Romaxx WD1
Joypad
Post by Lameiii »
I had been using a Gamepad (not Joy stick) for moving the router around when I'm setting up for a cut. I was on a XP computer with Mach 3 and it worked great.
I've now switched to a laptop with a UC100 cable which is working fine. However when I load the joypad software it doesn't work.
Has anyone had experience with Joypad's or used any other software/device that will let me control the router instead of using the keyboard?
Jim
Re: Joypad
I used to use a Logitech RumblePad 2 with the Logitech Wingman Software and that worked fine with all versions of Windows up to 10 when I stopped using it. I expect it works fine in 10 though as it worked in 8.
These days 99% of what I do is 8x4 sheets so there's no need to move the router around manually.
Lameiii
Re: Joypad
Post by Lameiii »
Thanks for the information. Where can I find the software Maybe it will work with my Logitech Dual Action gamepad.
Jim
Re: Joypad
Google search threw up this from the Logitech support site
http://support.logitech.com/en_us/produ ... 2#download
No idea if it will work though.
