Tried Something
Tried Something
Postby JMD » Mon Jan 18, 2016 10:03 pm
Tried carving on a curve. Oak slab from sawmill.
JMD
Model of CNC Machine: Shark Pro
Re: Tried Something
Postby scottp55 » Mon Jan 18, 2016 10:53 pm
NICE:)
Now you got me wanting to try it :)
How did you decide on Z origin?
Re: Tried Something
Postby JMD » Mon Jan 18, 2016 11:32 pm
scott[/quote]
First figured out the radius of the slab. Then laid out an oval dish shape and put the bear in it. Hard to explain. Think it was more luck than anything. :o
Drew shape of slab, end view, then put the radius of dish shape over it and adjusted until I though it would fit. I am sure that there is a way to do this with math, but that is a little past what I can do. Hope this helps. And sorry I can't be more help. :?
layout.crv
(103.5 KiB) Downloaded 358 times
JMD
Re: Tried Something
Postby scottp55 » Tue Jan 19, 2016 12:10 am
Thanks for the .crv and the explantion John! :)
Re: Tried Something
Postby Chuck26287 » Thu Jan 21, 2016 3:08 pm
I've never tried it before, but would this have been an application for setting the Z-origin reference at the bottom of the workpiece instead of the top?
Chuck26287
Model of CNC Machine: Axiom AutoRoute 8 Pro
Re: Tried Something
Postby PaulRowntree » Thu Jan 21, 2016 3:40 pm
That looks good, and the bark works well with the design. How will you keep the bark on the slab ?
Paul Rowntree
PaulRowntree
Re: Tried Something
Postby martin54 » Thu Jan 21, 2016 6:58 pm
Love projects like this that are a bit different from the normal, especially when you have to try & figure out where to put the piece on the table to get the machine to cut where you want. Thanks for sharing. I did a cake topper for someone a while ago where I had to do something along the same lines.
PaulRowntree wrote:That looks good, and the bark works well with the design. How will you keep the bark on the slab ?
Paul I did some centre pieces for my daughters wedding 2 years ago, she wanted them to look natural but I was worried that the bark would start falling off before the wedding. Covered them with a matt varnish which did darken then a little but it still looked pretty natural & the bark didn't start falling off. In fact they are still the same now as I have a couple of them in the workshop :lol:
Re: Tried Something
Postby JMD » Fri Jan 22, 2016 2:28 am
Never tried setting the Z-origin to the bottom. Not sure you can do that with a CNC SHARK. Machine always goes to 0,0,0 at the start of a cut.
JMD
Postby JMD » Fri Jan 22, 2016 2:30 am
[quote][/quote]
That didn't work like I planed
JMD
Re: Tried Something
Postby JMD » Fri Jan 22, 2016 2:34 am
Never though about that. When my son-in-law's father, a wood turner, gets back from FL I wisk ask him about that. I did give it 2 costs of sprat poly. That might do something.
JMD
Re: Tried Something
Postby scottp55 » Fri Jan 22, 2016 2:30 pm
JMD,
In my experience, IF the wood is dry and the bark is tight...it stays tight.
Both these pieces were KD 18 years ago and it's still tight except 2" on left of the moose blank(but the rest of the bark is keeping it in place).
And the Moose had been stuck in a 140F oven for an hour after carving to let linseed/beeswax saturate it.
I've got a bark on slab table 20 yrs old and that is still tight as well(all pics Maple though).
2 cents,
Re: Tried Something
Postby BillK » Wed Feb 03, 2016 4:17 pm
I've done this a few times. What I do to get the curve close is figure out how wide my carving is going to be and then round up another inch. So in this case say 4 inches. Mark out the 4 inches on the end of the log or round and measure up to the edge below the bark. Then use the arc tool to draw that with your measurements, do a two rail sweep for the length, and add your carving. Hope that helps.
BillK
BillK
Model of CNC Machine: CNC Shark Pro Plus
Re: Tried Something
Postby JMD » Thu Feb 04, 2016 2:07 am
BillK wrote:I've done this a few times. What I do to get the curve close is figure out how wide my carving is going to be and then round up another inch. So in this case say 4 inches. Mark out the 4 inches on the end of the log or round and measure up to the edge below the bark. Then use the arc tool to draw that with your measurements, do a C for the length, and add your carving. Hope that helps.
Thanks Bill K, but do not have the two rail sweep in VCarve Pro8. That would make things a lot easier. :)
JMD
Re: Tried Something
Postby BillK » Thu Feb 04, 2016 3:58 pm
Very good point. But before I had Aspire, I did the same with Sketchup and cut 3d. :D
BillK
BillK
Re: Tried Something
Postby JMD » Thu Feb 04, 2016 4:47 pm
BillK wrote:Very good point. But before I had Aspire, I did the same with Sketchup and cut 3d. :D
I will have to look into that. Thanks.
JMD
Return to VCarve - Gallery
