- Model of CNC Machine: Piranha
I have gone there, but I am not able to view the videos. Any suggestions as to how I can access them?
If you click on the video itself in your browser it should start playing.
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
How large of a file can I upload to Vectric Forum?
Thank You
3 MB as far as I'm aware. You can post a link to a file on DropBox, OneDrive or other file sharing service if it's bigger than that and can't be reduced by zipping.Creation in Wood wrote:How large of a file can I upload to Vectric Forum?
- Model of CNC Machine: BF-30 mill and 360 x 100 lathe
Why do my posts keep getting removed??
I don't even get a message informing me or explaining why. Heads up people... only say really nice things and how wonderful the software is on this forum!
Going to remove this one too??
Are you mentioning competing software made by other companies? This isn't a 3rd party CNC forum. It's provided and run by Vectric for their products so you can probably understand why they don't want other companies software "advertised" on it.
Not to mention the legal ramifications if someone joins into the thread make defamatory remarks about the other software.
- Model of CNC Machine: Legacy Arty
I would like to load more fonts on my Aspire software but dont know where to get them or how to install them. Any help would greatly be appreciated
- Mike-S
There are lots of sites with free fonts, like:
http://www.dafont.com/
Put them into your Windows font folder (may need to unzip first) and Aspire will automatically load them when it starts.
Here is a tutorial on how to install fonts - http://support.vectric.com/tips-and-tri ... video_id=5Royesslinger wrote:I would like to load more fonts on my Aspire software but dont know where to get them or how to install them. Any help would greatly be appreciated
As Mike says there are many sites with fonts available as the fonts Aspire uses (other than the single line ones) are standard True Type and Open Type fonts.
- Model of CNC Machine: Shark 3.0
Greetings,
I'm relatively new to CNC and need some advise. I have a CNC Shark and have just uploaded the 8.5 version of VCarve desktop. My question is what router bits would you recommend for engraving onto wood using point sizes from 12 to 72. I've looked on Amazon and they show several that are packaged in groups. Any help would be greatly appreciated.
Copper John,
Join the cnc shark forum http://www.cncsharktalk.com/viewforum.php?f=2 lot of info for shark owners. You can use 11 deg v bits , 45,60,90 v bits, etc... for wood.
Tony
Tony
Tony,
Thanks for your response.
Alan
Alan
- Model of CNC Machine: Oxzilla my own
Does anyone know what the new tool is that is called "Modeling ToolPaths" and what its for
My shop computer died and while I have a good copy on my home PC and I can transfer the program and files, I don't know how to get it installed on the new shop PC.
It's VCarve Pro 7.5.
I have sent an email request to support also.
Hi Guys (and hopefully Gals),
I found out my "Scale factor" setting in toolpath summary is not working for negative (lower/faster) numbers.
When I enter higher number than 1 result is immediately calculated, but my CNC seems faster and every time I try to get lower result than estimated time with scale factor one it doesn't calculate.
I tried negative numbers (-2.0), decimals 0.5 with both dot and with coma (0,8/0..
If I remember training it should be entered as decimal let's say "0.8"
I have win 10 and aspire 8.5.
Is this normal behavior or is it bug in the SW?
Thanks for useful advice in advance.
Yuri
Yuri
