These are my pictures in wood
Re: These are my pictures in wood
Xxray, are you using PVC or Aspire to do this sort of thing?? Might be that in Aspire the toolpathing is different.
Xxray
Post by Xxray »
Well all I can say it what I observe ,,, If its such a minute amount that it isn't even perceptible, I don't consider that a lift.
Xxray
Post by Xxray »
You are right it does retract, I got mine set to .10 so not much, but retract after each line it does.
MTSO
Model of CNC Machine: salecnc XJ1224
Post by MTSO »
here is a project I did recently, the finish is a epoxy resin, look very much the same as what has been used in this thread I used ACABADO BRILLANTE.
Regards
Brian
weber765
Model of CNC Machine: home built and modified Vytek rebel
Post by weber765 »
Thanks for sharing the ACABADO BRILLANTE finish you used it certainly looks like you hit it spot on to me and I will sure give it a try.
Glenn
jamesr
Model of CNC Machine: Inventables 1000mm X-CARVE
Post by jamesr »
Please tell me how you did this. I have an Inventables X-Carve and I have loaded Java and UGS on my computer. When I go to Vcarve photo tutorials and try to carve their sample photo's my machine only skims the wood. I have looked at their video's and have set my machine up just as they say. Also yesterday my machine went from skimming a photo sized area to only carving a 1 inch by 3/8 inch area and it is still doing that today. I have made sure I have inches in vcarve and inches in my UGS check marked. I am at a loss as where to go from here. Can you help?
jamesr
Post by jamesr »
I could sure use your help. I have the Inventables X-Carve and I am trying to carve photos using the v carve photo software and UGS. Using their (v carve photo) photo I tried to carve the woman photo, my machine carved from the bottom right to the top left at a 33 degree angle (set at .02 inch depth per v carve suggestion) and all I got was angled lines. Nothing resembling a photo at all. No texture, no depth, no anything. If you can give me any guidance here it would be greatly appreciated.
weber765
Post by weber765 »
To make the photo appear you will have to add a stain or paint and then lightly sand the surface to show the contrast. Have you done that yet ?
keralesh
Model of CNC Machine: 6040Z 1500W 4 Axis CNC Router
Post by keralesh »
WoodArt wrote:Here are some of the wood pictures i have made...hope you like them :D
http://www.youtube.com/watch?v=-a-fv0GOMtQ
http://www.youtube.com/watch?v=gY-kEWoPB_Q
http://www.youtube.com/watch?v=_HWe-djr-G8
Best regards,
/Markus Dahlberg
What type of wood do you use and how thick? Thanks
Keralesh, you would be better starting a new thread to ask your questions as the guy that first posted on this thread hasn't been on the forum for years
