clock face
jrj5x5
clock face
Post by jrj5x5 »
Is anyone else doing clocks?
I just started; any insight would be helpful.
CAMaster
Coreldraw X3, photograV 3.0 & Adobe cs2
Vcarve pro, Photocarve, Cut3D, Aspire
js11110
Re: clock face
Post by js11110 »
I've made a bunch....... I posted a few below. What might I be able to help you out with?
Jason
The Official Vectric Cartographer
You are limited only by your imagination
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Re: clock face
Post by calgrdnr »
Hmm I don't have any clock answer .. but looking at yours I am thinking your hands ie hour min, second hands should all be arrows with the point going into the sweet spot you drilled the hole for movement at or mayne kinda make bullseye out of the connection points ( of the hands with tip going in center ... Just m2c first thing that poped into my head when I noticed movement placement :)
jrj5x5
Re: clock face
Post by jrj5x5 »
calgrdnr wrote:Hmm I don't have any clock answer .. but looking at yours I am thinking your hands ie hour min, second hands should all be arrows with the point going into the sweet spot you drilled the hole for movement at or mayne kinda make bullseye out of the connection points ( of the hands with tip going in center ... Just m2c first thing that poped into my head when I noticed movement placement :)
Where do you purchase your clock parts?
Do you recess the guts into the back of the clock face or do you let it surface mount?
CAMaster
js11110
Re: clock face
Post by js11110 »
I purchase all my clock parts at: http://www.klockit.com/
Jason
Phil
Re: clock face
Post by Phil »
Another source for clock parts http://www.steebar.com/clocks/index.shtml
cstoutr
Model of CNC Machine: xcarve 1000mm
Re: clock face
Post by cstoutr »
How are yall laying out the numbers on the face. Are you getting them close or actually measuring them?
Frunple
Re: clock face
Post by Frunple »
cstoutr wrote:How are yall laying out the numbers on the face. Are you getting them close or actually measuring them?
You don't have to measure them. It's a 360 degree circle, divided by twelve. The software will do it all for you.
cstoutr
Re: clock face
Post by cstoutr »
I'm using xcarve pro. I understand what you are talking about how do I get The software to calculate it? Please bear with me, this will be my first clock. Thanks
glenninvb
Re: clock face
Post by glenninvb »
cstoutr wrote:I'm using xcarve pro. I understand what you are talking about how do I get The software to calculate it? Please bear with me, this will be my first clock. Thanks
Read how to use circular array tool...
http://forum.vectric.com/viewtopic.php? ... ock#p64307
cstoutr
Re: clock face
Post by cstoutr »
Awesome! I'm learning stuff everyday. Thanks for the link. Opens up so many new doors.
FixitMike
Re: clock face
Post by FixitMike »
A slightly different method of locating the numbers:
Draw a circle of the diameter and location where you want the centers of the numbers to be located.
Use the text tool to create any character (I use the number 1 for convenience). It can be placed anywhere, but preferably not on the circle .
Select the character and the circle (in that order).
Use the Copy Along Vectors tool to create 12 copies of the text around the circle.
Open the Draw Text tool and select and edit each character to the correct number.
Rotate each number in increments of 30 degrees if desired. But do this after the numbers are edited, since any time you edit text using the Draw Text tool, the text reverts to the original orientation (and spacing if kerned).
ohiococonut
Re: clock face
Post by ohiococonut »
I've carved a lot of 3D clocks and all of them have the mechanics recessed on the back. The hardest part is calculating the length of stem on the clock you'll need which is why I keep an assortment of them. Other wise you have to change the depth of your cut on either side.
