Monograms
drrobin
Model of CNC Machine: Handibot
Re: Monograms
Post by drrobin »
These are gorgeous and something I really want to do. I am brand-new to Cnc and everything about it. Would you care to post your toolpath and what type of bit that you used? I can create the monogram and welding just not sure what material thickness or tool to use or size it needs to be to get the best product. Thanks, Robin
buck4
Re: Monograms
Post by buck4 »
Robin, I use .375" (3/8 Inch) thick HDF fiber-board. Makes a lot of dust while cutting,
On some monograms I used a .250" end mill, others with lots of detail I used a .125" end mill.
Using the .250 em three pass at .125" each.
Using the .125 em you best use lighter pass, I did mine at .060" per pass
To get what I think is a better looking piece, I always change the text into vectors, and do a lot of node editing. Trying to make all the curves as smooth as I can, and to delete as many node as possible.
drrobin
Re: Monograms
Post by drrobin »
here's a screenshot of my tool path settings, the toolpath after cutting, and the final product. I selected all open vectors and nothing highlighted... What am I doing wrong!! All help appreciated. Thanks!!
preview of toolpath
preview of toolpath
Final product
Final product
vgraves
Model of CNC Machine: CNC Router Parts PRO4848 w/LinuxCNC
Re: Monograms
Post by vgraves »
Don't you want to cut Outside the vectors instead of On them?
drrobin
Re: Monograms
Post by drrobin »
Oh my goodness:-) That fixed the entire problem. Ran this so many times and didn't even notice that! Thank you so much!! Can't wait to try it on my machine. I've only done my test cut so far because they forgot to send the software with my 'bot' so trying to get several things created so I can cut when I get the official software! Thanks again!
Ms Wolffie
Re: Monograms
Post by Ms Wolffie »
zeeway wrote:Last name (surname) is middle initial. If it is the monogram for a couple, you would put the man's first initial first (of course...), then the surname initial and then the first initial of the woman.
Angie
I can understand that (sort of, except the gender order) however we both start with L so the order is not important but what if a single person does not have a middle name, how would you do that?
Cheers
Wolffie
Whatshammacallit
zeeway
Re: Monograms
Post by zeeway »
Guess you would do it the same way you would monogram an article of clothing - two equal size initials, or just one initial of the surname...but I am not an etiquette authority.
Angie
MattCI
Model of CNC Machine: Probotix Comet
Re: Monograms
Post by MattCI »
How are you guys holding the monogram in place when cutting? Are you using tabs?
zeeway
Re: Monograms
Post by zeeway »
I used tabs.
Angie
zeeway
Re: Monograms
Post by zeeway »
zeeway wrote:I used tabs.
Angie
gwandad
Model of CNC Machine: OpenBldOXHomebuilt&designed4thAxis
Re: Monograms
Post by gwandad »
Love your work!
Many thanks for the pointer to Fonts 2 U. I can't wait to try them.
turbotermit.dk
Model of CNC Machine: Einar CNC - homemade
Re: Monograms
Post by turbotermit.dk »
Looks great.
What do you use for finishing, if they are going to hang outside?
MDF and water, doesnt mix well
Cheers
Kris
paulschultz
Model of CNC Machine: Joe's Aluminum Plate R&P
Re: Monograms
Post by paulschultz »
How about using an "X"? Northern Michigan University has a building named after John X Jamrich. He doesn't have a middle name so they just gave him an X!! :shock:
drrobin
Re: Monograms
Post by drrobin »
I made a couple of monograms and loved them but finding with additional ones they are 'breaking' when I cut them. I use a 1/16 em but some of those letters are pretty fancy. Plus I was making some of them 8 inches which isn't much. The pine I tried (3/4 inch) chipped out. Then tried some maple-not much better. is there a better 'wood' and a best tried thickness someone wants to share?
The ones i had success with I did use an onionskin and was happy with that. A little sanding on the back and that flew right off...easy peazy:-)
Thanks, Robin
Ms Wolffie
Re: Monograms
turbotermit.dk wrote:Looks great.
Cheers
Kris
Hej Turbotermit fra en udenlands Dansker
Cheers
Wolffie
Whatshammacallit
