Napkin Holder
llwood
Napkin Holder
Post by llwood »
These napkin holders are a bit fragile. Marty said that 3 out of 9 chipped out pieces while they were being cut, but I don't think that they'd look as good if they were thicker.
After we did the first design with the stylized "H" for Hartman, we immediately got requests to do them with "S", "P", and "J".
Andy and Marty,
Locust Lane Woodworking
View from an angle
View from an angle
Top View
Top View
Front View
Front View
Front view with napkins.  It'd probably look better with larger napkins, but these were all we had right now.
dhellew2
Re: Napkin Holder
Post by dhellew2 »
Really nice design,great job, Dale
Young = time, no money
Old = money, no time
Dale
Jane Ndungu
Model of CNC Machine: TS1325
Re: Napkin Holder
Post by Jane Ndungu »
Hello Andy and Marty,
Hope this finds you well. That is truly a lovely lovely project. Would you kindly share the crv. file would love to do something like that. hope you don't mind.
Kind regards
Jane
Savannahdan
Re: Napkin Holder
Post by Savannahdan »
Very nice design. I've been working on a few napkin holders I need to have for our parish's Fall Festival. I'll post pictures when they are completed.
llwood
Re: Napkin Holder
Post by llwood »
Jane, here is the crv as requested. Both sides are identical, and we cut both sides on one piece of wood in order to minimize bit changes. However, this forum limits the size of the attachment to 2M and with both sides the file was too big. So I deleted the 2nd side and the file is 1.6M, small enough to upload. You can either cut the sides one at a time or recreate the 2nd side in VCP.
We carved a Script "H" in the center for our last name, but of course you can change this to whatever you want. Make sure you cut out the pockets in the center rather slowly so they don't chip out. We lost a few because of this.
Have fun!
Andy
Napkin holder for sharing.crv
(1.59 MiB) Downloaded 722 times
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Re: Napkin Holder
Post by sawmiller »
thanks for the example andy, your design is excellent
In the heart of Tn
Savannahdan
Re: Napkin Holder
Andy, thank you for the file. I ran it and figure I'd have 9 out of 9 fail on me. Just having one of those weeks.
Dan
subsea
Model of CNC Machine: Zenbot 2448
Re: Napkin Holder
Post by subsea »
Thank you for sharing. I wonder if I can make it or explode it. Ha, sometimes I just tear up things but I would like for this to turn out.
thanks, - Bill
llwood
Re: Napkin Holder
Post by llwood »
Dan, I wonder what can be done to have fewer fail. Perhaps slow the feed rates?
Larry.David.Preston
Model of CNC Machine: Custom
Re: Napkin Holder
Post by Larry.David.Preston »
On very fragile wood, like thin cherry, I've had success at finishing with diluted polyurethane and letting it dry thoroughly before machining. I'm not sure if there are other wood hardener out there that would also improve the strength of the fibers much better.
Savannahdan
Re: Napkin Holder
Oops, Andy, I think I misled you in thinking that I had try to cut the napkin holder and had a bunch of fails. I've been working on three other projects and haven't had time for the napkin holder, yet. I'll let you know what the outcome is. Hopefully I can get to it next week. It seems that on some projects we have to sort of stabilize the wood.
Dan
djoy707
Model of CNC Machine: shark pro HD
Re: Napkin Holder
Post by djoy707 »
Nice job on the napkin holder. and yes i will try this one . thanks djoy707
Ms Wolffie
Re: Napkin Holder
Post by Ms Wolffie »
Andy,
Thank you for the files, I don't think I have downloaded them before but.....
325 downloads WOW
A lot of people must like your design :D
Cheers
Wolffie
Whatshammacallit
Re: Napkin Holder
Just downloaded them myself, thank you very much for sharing them Andy
tajohns
Model of CNC Machine: Home built + Jtech 7watt Laser
Re: Napkin Holder
Post by tajohns »
Nice looking napkin holder.
Thanks for sharing.
Cheers,
Tom
Cheers,
Tom
