Hello everyone, I have modified the the thermwood 91000 PP to allow cutter radius compensation but this only works for profile cuts, all others like pocket and vcarving will still require you to input the proper bit diameter.
The way this works is by setting the bit diameter to .001" in the software and for our company we use conventional cuts for nearly everything so we use the G42 with an outside profile cut. This doesnt work for any other tool path because the software calculates the stepover for the bit based on the dia. so for this reason I have a copy of our most commonly used tools setup in the tool manager, one with the diameter at .001 and the other with the nominal diameter to use when machining pockets and such. Ill attach the PP I have made for you guys to use. If you have any suggestions I would like to hear them as I feel like there is a better way to approach this than what I have done but for the moment it work.
Thanks.
Thermwood cutter radius comp Post Processor
- Model of CNC Machine: Thermwood C48W
- Thermwood_ATC_91000_ARCS_inch.pp.txt
- This one I use for pockets and vcarving
- (4.93 KiB) Downloaded 266 times
- Thermwood_ATC_91000_ARCS_inch_G41.pp.txt
- (5.08 KiB) Downloaded 288 times
- Thermwood_ATC_91000_ARCS_inch_G42.pp.txt
- This is my most commonly used PP
- (5.51 KiB) Downloaded 253 times
Re: Thermwood cutter radius comp Post Processor
I have made a few changes to these in the past months, I added the text "START NEW FIGURE" to make it easier to tell the different cut paths and few other small changes to the codes to clean it up a little.
Dont forget you will have to change the extension of the file from "txt" to "pp" for it to work.
- Thermwood_ATC_91000_ARCS_inch.txt
- This PP is what I use for pockets and vcarving, there is no CRC in this PP
- (5.42 KiB) Downloaded 239 times
- Thermwood_ATC_91000_ARCS_inch_G41.txt
- This one is what I use for finish cuts on hardwoods since a climb cut leaves the best finish.
- (5.48 KiB) Downloaded 238 times
- Thermwood_ATC_91000_ARCS_inch_G42.txt
- This is what I use for all the plywood parts we cut we use a 3/8 compression bit cutting conventional and it works perfect.
- (5.49 KiB) Downloaded 254 times
Nice work. Would have never though of that.
Thanks!ger21 wrote:Nice work. Would have never though of that.
