Hi All, I have raised this topic maybe more than a year ago and received some advice from a few. I have since tried everything they mentioned, and due to the nature of the proposed remedies such as upgrading and improving the "insides" (I think it is the memory? anyway it is two pieces of micro circuitry the guy replaced) of my computer, it took some time to get around trying my luck with a Photo V Carve project again. As I think a lot of improvement happened when doing normal V Carving and Engraving, I was very hopefull that all problems have been sorted out.
However, my machine is still losing the actual -Z values as reflected on my display and read-out of the depths to be cut.........in other words, although, according to the tool path, the machine should be cutting at say eg. 1 mm, it does not even touch the surface! That being the case even although I have started cutting at the start of the program at the correct depth - that is 1 mm on the display=1 mm actually being cut. However, as the program progresses, say for example as from about command (coordinate) around 10 000 onwards, it increasingly looses depth until it does not even touch the surface where it is supposed to be cutting about 1.200 mm deep. The material is also 100% flat MDF product.
To prove that there is no structural or any other defect with the machine, I have actually proceeded to cut (in "jog" mode) a frame or square on 0.02 mm depth all the way around the picture and it is perfect. Yet, when the cutting of the Photocarve program has to be done, this gradual and ever increasing loss of depth occurs. I have even, as suggested, tried to run it as slow as 25% speed to prevent the loss of steps etc, etc.
I cannot say how frustrated and disappointed I am, as I am sure that I'm not the only grandfather who wants to do photos of the grandchildren.
If anybody out there have experienced a similar problem and can kindly share the secret to the solution, I shall be extremely grateful. Sorry for the lengthy post.
Mike
