Dovetail - Toolpath Gadgets
Postby seanm » Tue Oct 14, 2014 12:54 pm
Dovetail Gadgets
The Dovetail Gadgets are a powerful addition to the Vcarve Pro and Aspire software. The gadgets create the angular dovetail joints from the top of the material down rather than the traditional method from the side and using a special tool, this top down approach allows you to use a regular end mill to create the desired joint.
To view more information about this gadget and other gadgets, please visit the Gadgets Website or for a direct link to this gadget click here
seanm
Re: Dovetail - Toolpath Gadgets
Postby dnnis » Wed Mar 25, 2015 4:09 pm
I have vcarve desktop will this work for me
dnnis
Model of CNC Machine: built my own
Postby JamesB » Wed Mar 25, 2015 4:54 pm
None of the Gadgets run in the Desktop editions so it will not.
James
JamesB
Vectric Alumni
Postby Wazza » Thu Nov 10, 2016 2:37 pm
Not compatible with VCP ShopBot edition 8.5. I can download it, but it won't install. Same problem with the other gadgets. :cry:
Wazza
Model of CNC Machine: Handibot 2
Postby scottp55 » Thu Nov 10, 2016 3:15 pm
Wazza,
Make sure it's in the right folder...if not, then copy from a previous version that it probably installed in.
Postby Wazza » Tue Nov 15, 2016 2:18 am
Thanks, Scott,
That worked for the Chamfer gadget, but not the others. I don't have a previous version of VCP to copy from, I'm new to all this CNC stuff.
Wazza
Cannons Creek, Australia
Wazza
Postby scottp55 » Tue Nov 15, 2016 12:52 pm
Hmm...should work for all if it works for one:(
Are you showing data in the downloaded application files?
Maybe Adrian will kick in, and I'll see if I've got them in another location also.
NICE little town for a boat:)
Postby Drifter » Sat Dec 03, 2016 11:46 pm
Good evening,
I'm trying to install the dovetail gadget in version 8.0 I have 8.5 also but read someplace 8.5 doesn't have gadgets? i'm not seeing a gadgets tab in 8.0 either :cry:
Drifter
Model of CNC Machine: Shark HD4 Extended
Postby Drifter » Sun Dec 04, 2016 12:39 am
do I need to make a gadgets folder in one of the Vectric folders?
Drifter
Postby Adrian » Sun Dec 04, 2016 11:00 am
Desktop versions do not support gadgets and no trial version does either. If you have a professional version of Cut2d/VCarve or Aspire then they should work.
Postby Wazza » Sat Dec 10, 2016 4:14 am
Hi again, Scott,
Problem sorted - I have now successfully installed all gadgets.
When I was going thru' the instal process, I was not "unclicking" the version 8 box.
Both are ticked, whereas normally none would be selected in an installation wizard.
Thanks once again for your help. If you are ever in Cannons Creek I will pour you a beer!
Regards,
Wazza
Wazza
Postby scottp55 » Sat Dec 10, 2016 6:31 pm
Glad you got sorted Wazza:)
Doubt the beer though:)
Stay cool....-9C tonight and pond frozen here.
Postby GEdward » Mon Jul 17, 2017 10:41 pm
It is too bad that none of the gadgets will work on VC Desktop. I can do some pretty nice work as it is but I could use some of the gadgets to get more out of my machine. At 24" X 36" my machine is as large as I can manage from my wheelchair; so upgrading to pro is an expense just for the sake of additional features that are free for those that can afford it or have machines large enough to take advantage of all of pro's features.
G Edward
GEdward
Model of CNC Machine: Romaxx WD-1
Postby ger21 » Tue Jul 18, 2017 12:39 am
If you put your mind to it, you don't need gadgets to do what the gadgets do. If you learn how to do those things without gadgets, the sky will be the limit for you. People were doing these things long before there were gadgets, or even Vectric.
ger21
Postby Adrian » Tue Jul 18, 2017 7:24 am
How are those features free for those that can afford it? That's a bit of a contradiction in terms.
There are many more additions to the product other than just the ability to machine larger jobs. Nesting and toolpath templates are two such features that cost more than VCarve alone when bought from some other companies and are every bit as useful on a 2' x 3' machine as they are on an 8' x 4'.
Next
Return to Gadgets - Releases
Users browsing this forum: No registered users and 0 guests
