More Baby Picture Frames
Postby Carrie V » Fri Nov 21, 2014 6:05 pm
Gifts for my co-workers Babies
Carrie V
Model of CNC Machine: GerberSabre408, AXYZ 8010, Thermwood
Re: More Baby Picture Frames
Postby Carrie V » Fri Nov 21, 2014 6:21 pm
:) Here's my file
Baby Picture frame.crv
(1.97 MiB) Downloaded 618 times
Carrie V
Postby MarkJohnston » Fri Nov 21, 2014 6:48 pm
Nice job Carrie. I'm sure the people you gave this to will cherish it forever.
Mark
MarkJohnston
Model of CNC Machine: CAMaster MC4848
Postby glenninvb » Fri Nov 21, 2014 8:23 pm
Carrie,
Thanks for sharing!
They are very nice frames
glenninvb
Postby tonydude919 » Sat Nov 22, 2014 2:03 am
That is a very nice frame, thanks for the file.
Tony
tonydude919
Model of CNC Machine: cnc mako shark extended bed
Postby pops1964 » Sat Nov 22, 2014 4:16 am
Great job , thanks for the file . Pops
POPS1964
SHOPBOT Buddy BT-32
pops1964
Model of CNC Machine: shopbot buddy bt 32
Postby bill565 » Sat Nov 22, 2014 1:35 pm
Looks Great and thanks for posting the file.
Bill
Save the Whales, Collect the Whole Set
http://www.bcnc-fab.com
bill565
Model of CNC Machine: One of those "Practical"4x4s
Postby antennasDIY » Sun Nov 23, 2014 5:13 am
How did you get it painted so nice without a mask? My hand shakes like a drunk coming off the DT's after a night in lockup. Before you say huh? I observe this a lot at work..lol..
antennasDIY
Model of CNC Machine: Home made
Postby Carrie V » Sun Nov 23, 2014 3:08 pm
Thanks for all the great comments guys! :)
^^^ LOL antennasDIY, I also have the shakes. The trick is to try and paint it as carefully as possible with out driving yourself nuts. Yes I get paint up on the face and lots of it, I just keep a rag handy to wipe off the excess paint.
Then when it’s all painted and looks awful, I use an orbital or palm sander to sand off all the excess paint. I haven’t had too much problem with bleeding into the grain on the face. This is how I do it, I’m always amazed how crisp the painted letters look after sanding the face.
The paint I use is “Americana" Gloss Enamels, DecoArt.com". I buy it at "Michael’s Craft store”
Then I clear Coat after with a “satin,clear Varathane , premium, diamond wood finish, water based, interior, crystal clear, non-yellowing, ultimate protection, fast drying spray paint. I buy it at HomeDepot or Lowes building supplies stores, I spray 3 or more coats back and face.
Cheers,
:wink:
Carrie
Carrie V
Postby subsea » Mon Nov 24, 2014 3:04 pm
Interesting design. Thanks for the file.
- Bill
subsea
Model of CNC Machine: Zenbot 2448
Postby llwood » Thu Nov 27, 2014 2:06 am
Carrie and all,
Regarding the painting, do you think it would work to start with stock that is slightly thicker and do the VCarving first. Then paint and let dry. Then plane off the extra off the surface and run the rest of the toolpaths after that.
For example, currently the material size is 3/4". Imagine having a material size that is 13/16" and have the vcarving be 1/16" deeper then it is now. Then you could paint and be as messy and shakey as you want. It could even be applied with a spray gun. After the paint dries, do a pocket toolpath to shave off 1/16" off the entire piece and run the rest of the toolpaths with a start depth of 1/16". Do you think that would work on this project?
When we tried this we found out (the hard way), that sometimes the paint bleeds into the end grain, but by applying a coat of shellac first and then painting this didn't happen.
Anyone have any comments about this?
--Andy
llwood
Postby bill565 » Thu Nov 27, 2014 12:43 pm
I will apply sanding sealer before I cut. I find this leaves a clean edge around the cuts that wont bleed. Simple to wipe off or sand when complete for final finish.
I tried the large pocket to skim the surface, but my original took longer to pocket than the simple sanding/wiping and it would need sanding as well with some of the tooling marks left. Yes these can be minimized with settings and cutter choice but ultimately I have found sealing prior to be the best for my applications.
Just my two cents.
bill565
Postby antennasDIY » Wed Feb 11, 2015 7:40 pm
Thanks so much for the files and inspiration! I made one. Well I tried one but ended up making 3 cracks at it. Forgot to change the bit once and it ran the toolpath with a V bit instead of the endmill. Ooops.
I painted the edges but I won't do that again. I'll just leave it natural.
Thanks again!!
AntennasDIY
baby plaque
antennasDIY
Postby sunshinejim » Thu Feb 12, 2015 3:36 pm
Very nice frames - a suggestion for the glass, backing & hold in tabs - I go to the Dollar store and buy a suitable size frame for about $2.00 or less - throw away the frame and use the rest for my frame. If you can find the right size you don't even have to cut the glass.
sunshinejim
Postby esteeme1 » Fri Feb 13, 2015 4:37 am
Now that will sell. Just when the heart of pre natal nurse and start selling.
Jim Darlas
"Can Do!"
esteeme1
Next
Return to VCarve - Gallery
Users browsing this forum: No registered users and 9 guests
