Touch plate on the Piranha
- Model of CNC Machine: Piranha
Where does the touch plate connect to the Piranha ? It looks like it could be the controller or the display. Thanks for any help.
Re: Touch plate on the Piranha
Thank you.
What is the jack on the side of the controller for, do you know??
Sorry, I meant on the side of the display panel
- Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
sorry don't know. But if you post this same questions over at the shark forum,
Tim Owens from nextwaveautomation will often chime in.
"Out of my mind. Back in 5 Minutes."
The touch plate does not work plugged into the controller, it needs to plug into the small display. The system does not see the touch plate plugged into the controller but works just fine when plugged into the small display unit.
well then that means the plug in the controller will be for the digital probe.
- Model of CNC Machine: Piranha LX
Where is the touch plate placed on the material?
Depends where you want the z zero to be. If you have z zero set to Material Surface then a touch plate is placed on top of the material. If it's set to Table Surface then it's placed on top of the spoilboard.
Is it placed at the XY datum?
