Another Coat of Arms
- Alan Male
- Model of CNC Machine: heiz 400T
Here's the latest commission.
It took nearly 10 hours to machine.
It's finished with 3 coats of Danish Oil (no sanding).
Cheers...
Cheers...
CNC m/c - Heiz 400T
CAD - Catia V5
CAD - Catia V5
Re: Another Coat of Arms
Nice work Alan. Coats of Arms are my favorite CNC projects. What kind of wood did you use? Mahogany?
- Alan Male
Not mahogany, it was Sapele
CNC m/c - Heiz 400T
CAD - Catia V5
CAD - Catia V5
- scottp55
NICE Job Alan!
- Model of CNC Machine: shopbot buddy bt 32
Great job Alan , really like the finish. pop's
POPS1964
SHOPBOT Buddy BT-32
SHOPBOT Buddy BT-32
- Model of CNC Machine: CNC router
Very nice work, both carving & finish!
I'm curious, did you create the design in Aspire?
RickO
- Alan Male
Yep, all done in Aspire including a couple of traced bitmaps given a 3D depth using Aspire's modelling tools.
CNC m/c - Heiz 400T
CAD - Catia V5
CAD - Catia V5
- Model of CNC Machine: Shark Pro Plus HD & Custom built 4x4
Looks really nice Alan.
It does resemble mahogany but the Sapele carved really clean. I tried a piece of African Mahogany once and was left with a lot of fuzzies.
- Model of CNC Machine: Gantry Router - self designed
Well done sir.
Life is, Live it
Aspire 9.5, SolidWorks CSWA
CNC Gantry, FDM/FFM, Resin
MM0MSU
Veteran USAR
MM0MSU
Veteran USAR
That is beautiful Alan, congratulations!
Paul Rowntree
Do you find that consistently machines well Alan? I thought it was Sapele the Double Glazing firms use for finishing the inside of new windows, they say it's mahogany but I'm pretty sure it isn't. I pick bits out the unit next to mines skip & the density of it seems to vary enormously, some machines well some doesn't.Alan Male wrote:Not mahogany, it was Sapele
Nice work on the Coat of Arms by the way, sure customer is delighted.
- Alan Male
Hi Martin,
I guess I've been lucky so far.
I bought a 1" thick (as sawn) 6 foot plank from a local company that machines various mouldings.
This Coat of Arms was using my last piece, so if I get asked to make any more I may suffer your experience.
Cheers for the heads-up.
Alan
Alan
CNC m/c - Heiz 400T
CAD - Catia V5
CAD - Catia V5
Alan, maybe they are careful what they buy in if they are machining themselves. It's pretty easy to tell anyway by the weight & colour, the denser wood is darker in colour & obviously heavier. It all machines it's just that some of it needs some cleaning up after machining to get rid of the fuzzies.
Hey Alan, beautiful piece.
You said total machine time was 10 hours or so.. Mind my asking what your charging? Reason is I have been asked to do one as well and I am lost as to what to quote them!
Thank you for your time!
Deric
Deric
- Alan Male
Hi Deric,
This coat of arms was for a friend, so the charge to him (£60) was more for my programming time.
However, there was a good discussion recently on the forum "What to charge for making stuff" it's well worth a read.
Hope it goes well for you.
Cheers - Alan
Cheers - Alan
CNC m/c - Heiz 400T
CAD - Catia V5
CAD - Catia V5
