The all time great topics from elsewhere on the forum
Postby abdr10 » Wed Feb 19, 2014 3:55 pm
Hi,
Just i want to know if there is way to write arabic text on vcp instead import them as dxf from coreldraw ?
Abdulrahim
abdr10
Model of CNC Machine: TAIG CNC
Postby 4DThinker » Wed Feb 19, 2014 11:14 pm
If you have a windows truetype font of Arabic letters then it should be possible. VCarve uses Windows compatible fonts.
4DThinker
Postby Rcnewcomb » Thu Feb 20, 2014 12:32 am
Since VCP doesn't do special handling for right-to-left script you get some odd behavior.
You can type the characters into the text box, but when you hit apply the characters will be in reverse order on the project. Therefore you have to switch the order of the characters around in the text box. If you are doing something simple it's no problem, but of there is a lot of text it would be easier to import from CorelDraw.
See below. The order is correct in the text box but reversed on the project. The same is true for Hebrew.
Postby Stan » Sat Mar 29, 2014 7:26 am
Hi,
I have VCarvePro. And I have a question. I want to buy - Cut 3D for STL files. Will I be able to save 3D files in Cut 3D and then open in the program VCarvePro? As I understand it is possible. In the program Cut 3D need to open STL file and save to format - v 3d. Then in the program VCarvePro to import this - v 3d file. I'm not very advanced user of the computer and just want to be sure.
Thank you
Stan
Model of CNC Machine: High-Z S-720/T
Postby Adrian » Sat Mar 29, 2014 9:33 am
Yes it works as you describe. Save in Cut3D format and import.
Tutorial D03 on this page - http://support.vectric.com/tut-vcp-2d-techniques - goes through the process.
Postby Stan » Sat Mar 29, 2014 3:00 pm
Thank you.
Stan
Postby Roy Esslinger » Fri Apr 04, 2014 10:40 pm
I have made all the projects I can that have been posted on the vectric website and have had a lot of fun learning how to run my machine. Is there other sites that you can suggest to me to get other project to make. I don't mind even paying for them if I have to
Roy Esslinger
Model of CNC Machine: home built
Postby Adrian » Sat Apr 05, 2014 8:48 am
You could try http://shopbottools.com/mSupport/projects.htm
A lot of the Vectric projects are there but there are some others that will work with VCarve as the ShopBot PartWorks program is essentially the same thing.
Jon at http://cncking.com/shopbot-table-router-projects.html has some interesting items as well. Make sure you read and understand the license agreement though.
Postby Tde1806 » Wed Apr 09, 2014 11:35 pm
hi vectric
I have recently received to another email account than the one I previously purchase vcarve pro with.
I have no longer have access to the old email account.
is it possible to change my user information to the new email account
Tomas
Autograv IV
1000 x 600
Vcarve pro. v6.5
Autocad 10
3Ds max 2011
Autodesk Inventor 2012
Tde1806
Postby ssflyer » Thu Apr 10, 2014 4:01 am
Hi Tomas,
Send an e-mail to support@vectric.com - they can take care of your issue.
Ron Sloan
ssflyer
Postby lcp9073 » Mon Apr 21, 2014 8:12 pm
How long does it usually take for a reply from sales or support? I've got $1500 burning a hole in my pocket for an upgrade to aspire and haven't heard from anybody since Thursday.thanks!
lcp9073
Model of CNC Machine: built myself
Postby PaulRowntree » Mon Apr 21, 2014 10:33 pm
Usually they are very prompt, but holiday weekends can slow them down a bit. Family stuff and all.
Paul Rowntree
PaulRowntree
Postby lcp9073 » Tue Apr 22, 2014 2:52 am
oops, forgot about the holiday weekend, sorry:-)
lcp9073
Postby sailfl » Tue Oct 14, 2014 11:45 pm
Where are the gadgets stored on my computer hard drive? Or where am I suppose to store them?
sailfl
Model of CNC Machine: MechMate
Postby mezalick » Wed Oct 15, 2014 12:03 am
I think they go into the Vectric Files folder in the Public section of Documents ..
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
PreviousNext
Return to Technical Archive
